Old 08-23-2016, 10:49 AM   #1
1968 24' Tradewind
Tulsa , Oklahoma
Best Water Pump?
The Shurflo pump in our 68 Tradewinds has gone out and Im wondering what brand I should buy. The previous owner went through several Shurflos before we bought it and I thought I would try a different brand. I was about to buy a REMCO till I saw a review that said it was faulty and put extreme pressure in his lines which blew many of his connections. Yikes, I currently have a 2.8 GPM model which is fine for my small trailer. Any thoughts out there?
Eric James is offline   Reply With Quote
Old 08-23-2016, 01:29 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Keep in mind GPM is the inverse to filling gray water tank. You are not watering the lawn.
Marketers try to make people think they should have in their camper what they have at home. I have a device on my bathroom sink that gets it down to less than a qt. per min. and requires my hand has to in the water flow to stay on.
Consider installing an accumulator to reduce the cycle count on the pump.
2004 Excursion 4x4
Old 08-23-2016, 06:13 PM   #3
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
I'm using a 2.8-GPM water pump and it delivers plenty of water. I have an accumulator tank which smooths out the water flow, so that when, for example, we take a shower, the the flow is smooth with plenty of pressure. The only negative aspect of the accumulator tank is that it makes winterizing a bit more difficult. That problem was solved by going to AZ from November to April.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 08-23-2016, 06:17 PM   #4
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
If you have anything left in the piggy bank, get a Jabscco Marine pump.
Old 08-23-2016, 06:24 PM   #5
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
SHURFLO 3GPM 12v pump is all you need. Runs like a champ and only costs $55 no tax or shipping costs, available from various online retailers. Takes all of 10 minutes to swap pumps.
The 3GPM model supersedes the older 2.8 GPM versions from SHURFLO....
http://shurflo.com/rv-products/rv-pu...12-vdc-3-0-gpm
wulfraat is offline   Reply With Quote
Old 08-23-2016, 06:47 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
How do you know the existing pump is bad?
Old 08-23-2016, 09:58 PM   #7
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Over the years I've had 3 water pumps fail, all without warning, and at inopportune times. As a result, I carry a spare in a zip lock bag right beside the working pump. I've had to swap one out on a Sunday morning while Boondocking in the Sonora Desert.
VE3JDZ
AIR 12148
Old 08-25-2016, 12:10 AM   #8
1995 30' Excella
Lakeway , Texas
Shurflo is always a good bet, mine has held on nearly 20 yrs...rattles a bit tho
jbs411 is offline   Reply With Quote
Old 10-11-2016, 09:29 AM   #9
Vantair
2005 25' International CCD
Westlake Village , California
Agree with Wulfraat.
11yr old original Shurflo simply made unnecessary racket. With all the good hype on the new Revolution series (about same cost as an additional accumulator) Swapped out to the 4008. Also added quiet kit to decouple the vibrations even more.
VERY much improved performance and MUCH lower pump noise.
Highly recommended.
Relaxing is hard work.
Vantair
2005 25ft International CCD SS
2014 GMC Sierra Denali 1500 4X4 int. 3.43 Int sway/tow controller
1981 Honda Trail CT110 1X0..no sway control
Vantair is offline   Reply With Quote
Old 10-11-2016, 11:12 AM   #10
wulfraat's Avatar
Yup I've got the same pump. It works well for the $$.
Old 10-11-2016, 12:27 PM   #11
wulfraat's Avatar
Signs of aging can include increased noise, increased vibration, higher amperage draw, reduced water pressure while pump is cycling...
Signs of failure - water stops being pumped in one side and out the other
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 07:46 PM
Pump in RV Antifreeze Downstream from the Water Pump? KJRitchie Winterizing, Storage, Carports & Covers 6 01-09-2015 02:18 PM
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 9 10-02-2013 11:55 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 03:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 11:11 AM
