Old 06-21-2013, 01:16 PM   #29
crabbey1's Avatar
1976 Argosy 22
Pasadena , California
Images: 33
Send a message via AIM to crabbey1 Send a message via Skype™ to crabbey1
Awesome! Great to hear! I am going to pick one up.
crabbey1 is offline   Reply With Quote
Old 06-21-2013, 01:22 PM   #30
andreasduess's Avatar
1984 34' International
Toronto , Ontario
Originally Posted by dznf0g View Post
Here are many examples:
Amazon.com: water alarm
Is there a specific model you'd recommend?
andreasduess is offline   Reply With Quote
Old 06-21-2013, 01:48 PM   #31
crabbey1's Avatar
1976 Argosy 22
Images: 33
Is there such a thing a low flow valve? Or does the showerhead just take care of that on it's own?
Old 06-21-2013, 01:56 PM   #32
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
It doesn't require a special shower valve. The design of the showerhead itself is what reduces the flow, you could use one in your house for that matter.
The one in the Camping World link I sent you has a shutoff valve included at the base of the showerhead, so you can temporarily stop the water flow without tinkering with the shower valve settings (nice for my fiddly original 2-handle shower valve.) The standard setup from Oxygenics comes with a restrictor that lets you reduce the flow but not completely shut it off.
— David
DKB_SATX is online now   Reply With Quote
Old 06-21-2013, 05:17 PM   #33
Toronto , Ontario
Useful stuff! I just ordered two water detectors for our AS. Thanks for sharing your experiences.
Old 06-22-2013, 09:04 AM   #34
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Heads up on the so called "on/off valve" on the new Oxygenics shower head. I am on my third one from Camping World. The valve will not shut the water off. All it does is reduce the flow to a high trickle. Read the reviews that people are posting on the new head and others are having the same problem. I am debating if I am going to send the latest one back and try again. As a shower head it works very well. Supposedly uses less water and has a nice spray pattern with good pressure.
MICHAEL
Old 06-22-2013, 10:12 AM   #35
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
I didn't think it was supposed to shut the water off entirely, the trickle is there to remind you to shut the shower valve off properly. We have the Airstream supplied shower head that has a cut off valve but it specifically says there should be a trickle....
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 06-22-2013, 10:52 AM   #36
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
We dry camp quite a bit (I know, it's not everyone's thing). In place of the charger/convertor I have a Xantrex charger/inverter - the Freedom 3012 (3000 watt pure sine wave output). Also have 3 x 75-watt solar (came with the trailer), 4 AGM batteries and I installed a blue-flame heater.
For internet I use the cellular network. I had a cell antenna mounted on the roof (the aluminum roof makes an excellent counterpoise (ground plane). The antenna is attached to a Wilson 3-watt amplifier with an internal pickup. I use an older Cradlepointe router into which I plug a Verizon USB cellular modem. The Cradlepointe sets up a complete wireless network in the trailer - works with Linux, Windoze, iPod, Andoid and what ever else needs internet access, as well as the printer.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 06-22-2013, 11:42 AM   #37
AWCHIEF's Avatar
Images: 33
Toad, not so. According to camping world and the maker it is supposed cut the water off completly. It is a defect in manufacturing . I called CW this morning and they are going to send another one. I was told they have received no complaints from the latest batch they have sent ouy. Hopefully this one will work as designed.
MICHAEL
Old 06-22-2013, 11:50 AM   #38
MrUKToad's Avatar
Chatham , Ontario
Ah well, you live and learn...
Old 06-22-2013, 01:48 PM   #39
crabbey1's Avatar
1976 Argosy 22
Images: 33
Where can I pick up one of the Cellular Antennas? I usually use my Sprint phone as a WIFI hotspot and then use my computer. If having an antenna and an amplifier will help boost service, I would love that!
Old 06-22-2013, 06:32 PM   #40
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Originally Posted by m.hony View Post
Where can I get some pink flamingos?
Lot of 4 Vintage Original Don Featherstone Signed Pink Flamingo Lawn Ornaments | eBay
Old 06-22-2013, 08:32 PM   #41
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Them birds ain't got no legs!
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 06-23-2013, 08:49 AM   #42
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
I bought my antenna through Amazon. The manufacturer of the antenna and the booster/amplifier is Wilson. They have a variety of differently configured kits - I go the amplifier with the internal antenna which has a pick-up range of 2 feet; it has the 12-volt power supply and I also bought the plain antenna. I has JC install the antenna, and I put the amplifier under the armrest of the gaucho (wired in 12volts for it there). The pickup is attached with the double-sided tape it came with just under the window ledge where the dining table folds out from the wall. I also wired in a small switch under the window ledge (switch has a red led in it when the power is on) to power the amplifier on and off.
VE3JDZ
AIR 12148
