Old 06-29-2015, 11:18 AM   #1
2010 30' Flying Cloud
Sandy , Oregon
Best Jack for lifting 30' FC.. to change tire
Can some one recommend a good jack that does not take up much space?
Thanks...
carlose is offline   Reply With Quote
Old 06-29-2015, 11:27 AM   #2
AWCHIEF's Avatar
2006 23' Safari SE
Biloxi , Mississippi
Images: 33
Andersen Levelers, multi purpose for leveling, chocking and flat changing.
MICHAEL
Old 06-29-2015, 12:05 PM   #3
The Ice Man's Avatar
2011 27 FB International
Tucson , Arizona
Trailer Aid; don't leave home without it.
http://www.amazon.com/Trailer-Aid-Ta...ords=RV+chocks
The Ice Man is offline   Reply With Quote
Old 06-29-2015, 12:53 PM   #4
1987 25' Sovereign
Oregon , Ohio
Totally agree with statement. Best thing for this since sliced bread.
msmcv51 is offline   Reply With Quote
Old 06-30-2015, 06:49 AM   #5
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I carry a 6t bottle jack. The case it comes in is about 12"x8"x5" and weighs about 6 lbs I guess. I use some pressure treated 2x8's for leveling and if needed to change a tire. The jack is used if I need to get both wheels off the ground OR if the front jack poops out on me and I need to lift the A-frame to get it on or off the ball. It has come in handy a few times.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 06-30-2015, 07:54 AM   #6
Kevin245's Avatar
Concur with the levelers from Andersen or the trailer ramp. They are lightweight and work well on dual axle rigs. Though I used my TV OEM jack this weekend on the return trip home when I noticed my curbside rear wheel was very hot.
Anyone see the cause in the attached photos?
ID:	241933   Click image for larger version
William C. Swinney
Old 06-30-2015, 08:23 AM   #7
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
You have an F350 tow vehicle. Take a look at its Jack. I use one from a Dodge 1 ton. Works fantastic on my 30' slider.
GCinSC2 is offline   Reply With Quote
Old 07-09-2015, 04:38 PM   #8
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Originally Posted by Kevin245 View Post
<snip>.... I noticed my curbside rear wheel was very hot.
Looks like you had something caught between the brake magnet and the drum; the drag caused the brake to activate and cook itself to bits. which also caused the wheel to be hot.
No?
"Between what matters and what seems to matter, how should the world we know judge wisely?" - E.C. Bentley, Trent's Last Case
drboyd is offline   Reply With Quote
Old 07-09-2015, 05:27 PM   #9
daveswenson's Avatar
2012 28' International
Olympia , Washington
I'm not seeing any friction material left on the shoes.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 07-09-2015, 05:28 PM   #10
2020 30' Classic
2016 30' Classic
Covington , Louisiana
I second the trailer aid. Amazingly simple, easy to use and inexpensive!
Sjcjr is offline   Reply With Quote
Old 07-09-2015, 09:29 PM   #11
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
6Ton bottle jack and load spread boards.
Our 3 axle would require multiple Andersons... or, increasing levels of 'Legos'...on the opposite tires.
Peace and Blessings..
Channing
WBCCI# 30676
Best Jack to Change Tire on Single Axle Sport Cannonball Jacks, Stabilizers, Lifting and Leveling 29 12-07-2017 09:50 AM
Jack placement for tire change ferrygj99 Tires 4 05-10-2013 08:15 PM
Placement of jack for lifting sepezlover Jacks, Stabilizers, Lifting and Leveling 13 02-22-2011 02:36 PM
Window Lifting Arm Repair Davydd Windows & Screens 9 08-22-2003 07:23 PM
Manual Jack Broken - Best Elec. Jack? montanaandy Jacks, Stabilizers, Lifting and Leveling 9 07-10-2003 06:33 AM
