Old 06-29-2015, 11:18 AM   #1
2010 30' Flying Cloud
Sandy , Oregon
Best Jack for lifting 30' FC.. to change tire
Can some one recommend a good jack that does not take up much space?
Thanks...
carlose is offline   Reply With Quote
Old 06-29-2015, 11:27 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Andersen Levelers, multi purpose for leveling, chocking and flat changing.
MICHAEL
Old 06-29-2015, 12:05 PM   #3
The Ice Man's Avatar
2011 27 FB International
Tucson , Arizona
Trailer Aid; don't leave home without it.
http://www.amazon.com/Trailer-Aid-Ta...ords=RV+chocks
The Ice Man is offline   Reply With Quote
Old 06-29-2015, 12:53 PM   #4
1987 25' Sovereign
Oregon , Ohio
Totally agree with statement. Best thing for this since sliced bread.
msmcv51 is offline   Reply With Quote
Old 06-30-2015, 06:49 AM   #5
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I carry a 6t bottle jack. The case it comes in is about 12"x8"x5" and weighs about 6 lbs I guess. I use some pressure treated 2x8's for leveling and if needed to change a tire. The jack is used if I need to get both wheels off the ground OR if the front jack poops out on me and I need to lift the A-frame to get it on or off the ball. It has come in handy a few times.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 06-30-2015, 07:54 AM   #6
Kevin245's Avatar
Concur with the levelers from Andersen or the trailer ramp. They are lightweight and work well on dual axle rigs. Though I used my TV OEM jack this weekend on the return trip home when I noticed my curbside rear wheel was very hot.
Anyone see the cause in the attached photos?
ID:	241933   Click image for larger version
Eleanor Roosevelt
Old 06-30-2015, 08:23 AM   #7
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
You have an F350 tow vehicle. Take a look at its Jack. I use one from a Dodge 1 ton. Works fantastic on my 30' slider.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 07-09-2015, 04:38 PM   #8
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Originally Posted by Kevin245 View Post
<snip>.... I noticed my curbside rear wheel was very hot.
Looks like you had something caught between the brake magnet and the drum; the drag caused the brake to activate and cook itself to bits. which also caused the wheel to be hot.
No?
Old 07-09-2015, 05:27 PM   #9
daveswenson's Avatar
2012 28' International
Issaquah , Washington
I'm not seeing any friction material left on the shoes.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 07-09-2015, 05:28 PM   #10
2015 30' Flying Cloud
2016 30' Classic
Covington , Louisiana
I second the trailer aid. Amazingly simple, easy to use and inexpensive!
Sjcjr is offline   Reply With Quote
Old 07-09-2015, 09:29 PM   #11
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
6Ton bottle jack and load spread boards.
Our 3 axle would require multiple Andersons... or, increasing levels of 'Legos'...on the opposite tires.
Peace and Blessings..
Channing
WBCCI# 30676
Best Jack to Change Tire on Single Axle Sport Cannonball Jacks, Stabilizers, Lifting and Leveling 29 12-07-2017 09:50 AM
Jack placement for tire change ferrygj99 Tires 4 05-10-2013 08:15 PM
Placement of jack for lifting dorfgog Jacks, Stabilizers, Lifting and Leveling 13 02-22-2011 02:36 PM
Window Lifting Arm Repair Davydd Windows & Screens 9 08-22-2003 07:23 PM
Manual Jack Broken - Best Elec. Jack? montanaandy Jacks, Stabilizers, Lifting and Leveling 9 07-10-2003 06:33 AM
