06-29-2015, 11:18 AM
2010 30' Flying Cloud
Sandy
, Oregon
Best Jack for lifting 30' FC.. to change tire
Can some one recommend a good jack that does not take up much space?
Thanks...
06-29-2015, 11:27 AM
Biloxi
, Mississippi
Andersen Levelers, multi purpose for leveling, chocking and flat changing.
MICHAEL
06-29-2015, 12:05 PM
2011 27 FB International
Tucson
06-29-2015, 12:53 PM
1987 25' Sovereign
Oregon
, Ohio
Totally agree with statement. Best thing for this since sliced bread.
06-30-2015, 06:49 AM
retired USA/USAF
2001 30' Excella
Somerset
, New Jersey
I carry a 6t bottle jack. The case it comes in is about 12"x8"x5" and weighs about 6 lbs I guess. I use some pressure treated 2x8's for leveling and if needed to change a tire. The jack is used if I need to get both wheels off the ground OR if the front jack poops out on me and I need to lift the A-frame to get it on or off the ball. It has come in handy a few times.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
06-30-2015, 07:54 AM
Concur with the levelers from Andersen or the trailer ramp. They are lightweight and work well on dual axle rigs. Though I used my TV OEM jack this weekend on the return trip home when I noticed my curbside rear wheel was very hot.
Anyone see the cause in the attached photos?
William C. Swinney
06-30-2015, 08:23 AM
2007 30' Classic S/O
Somewhere
, South Carolina
You have an F350 tow vehicle. Take a look at its Jack. I use one from a Dodge 1 ton. Works fantastic on my 30' slider.
07-09-2015, 04:38 PM
1978 25' Tradewind
Metro Phoenix
Originally Posted by Kevin245
<snip>.... I noticed my curbside rear wheel was very hot.
Looks like you had something caught between the brake magnet and the drum; the drag caused the brake to activate and cook itself to bits. which also caused the wheel to be hot.
No?
07-09-2015, 05:27 PM
2012 28' International
Olympia
I'm not seeing any friction material left on the shoes.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
07-09-2015, 05:28 PM
2020 30' Classic
2016 30' Classic
Covington
, Louisiana
I second the trailer aid. Amazingly simple, easy to use and inexpensive!
07-09-2015, 09:29 PM
1999 34' Excella
Hillsboro
6Ton bottle jack and load spread boards.
Our 3 axle would require multiple Andersons... or, increasing levels of 'Legos'...on the opposite tires.
Peace and Blessings..
Channing
WBCCI# 30676
