Old 01-19-2013, 04:50 AM   #1
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Bent Stabilizer Jack - Need Replacement
I ran over a truck tire tread on the interstate. The stabilizer jack rod was bent badly. I need a new stabilizer. Seems simple enough.
But I am not sure what Airstream used. Mine appear to be telescopic, or T shaped design. Two bolts on the frame, one bolt on the cross member.
What is the correct replacement part, and where can I get one?
David
Old 01-19-2013, 05:32 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
You need a BAL 400093 stabilizer. When you call to order it, make sure you specify you only need one, not the set of four.
You can get them from any Airstream dealer, including the one in the same town shown in my profile.
Old 01-19-2013, 07:09 AM   #3
sandlapper's Avatar
1993 34' Excella
York , South Carolina
Are the ones on the Limiteds electric?
John
WBCCI #3892 Palmetto State Airstream Club 22
Region 3 , 1st VP
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 01-19-2013, 07:40 AM   #4
Well Preserved
1993 21' Sovereign
Some are, but not all of them. The part number above is for manual crank stabilizers.
Old 01-19-2013, 08:23 AM   #5
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Thank you Overlander. Mine are hand cranked, which is just fine.
David
