Old 04-03-2014, 10:40 AM   #1
dznf0g's Avatar
Oswego , Illinois
Belt molding sealing idea
So I am battling some new water leaks and since I have new molded in color lower molding inserts sitting in the basement, it might be time to remove the lower molding and reseal the whole shootin' match. I got to thinking about how to seal the rivet heads and seams under the molding and thought an Eternabond product would be much longer lasting than sealer. The only 1" wide product they make is here:
EternaBond Doublestick MicroSealant Putty Tape
However, it is a double sticky sided product and I would never get the molding off again in the future. I called and discussed with a tech at Eternabond and he thought it would be a good application for this product...and just go back over the outside of the tape with aluminum foil before the molding is re-installed.
What do you all think?
Will 1" cover both the rivets and the lap joint between the skin and belly wrap?
Will .060" thickness cause my moldings to be very much short as they run around the trailer due to standing out a tiny bit more?
Anything I'm missing?
-Rich-
Suitable belt and lower trim molding inserts dznf0g General Repair Forum 11 12-04-2017 12:32 AM
T-Molding (Tee Molding) Trouble and Solution! shane_franz Cabinets, Counter Tops & Furnishings 0 07-05-2013 12:09 PM
Sealing belt-line trim? Friday Clearcoat, Exterior Paint & Trim 6 06-20-2012 09:18 AM
Total electric. Good idea or bad idea? EZstream Generators & Solar Power 34 08-17-2011 08:40 PM
Need help to get a belt line molding nmayer1 Clearcoat, Exterior Paint & Trim 3 05-24-2011 02:49 PM
