Old 03-11-2014, 06:25 PM   #1
huntingdon , Pennsylvania
belly pan
what metal is used for the belly pan on my 1974 soverign ? is this aluminum because it has holes rotted in it like galvanized does?
where is the best place to purchase these sheets of metal?
thanks
kokomoscalls is offline   Reply With Quote
Old 03-11-2014, 06:45 PM   #2
1981 31' Excella II
New Market , Alabama
I think I used .032" thick 6061-T6 but 5052-H32 will work fine as well. A local metal supply store should have the stuff or can get it. There is probably other rotted stuff above the belly pan. Remove the insulation and paint the frame with POR15. Don't put fiberglass back in.
Perry
Old 03-11-2014, 06:55 PM   #3
Bauxter's Avatar
1973 31' Sovereign
Columbus , Ohio
I used 3003 .032 for the pan, and .027 or .029 (not sure) for the belly wraps...way easier to form
The mother ship sells sheets around 62" wide x however long you need. Its an interesting place to visit, too
Bauxter is offline   Reply With Quote
I was afraid of the belly pan Dingo Girl 1966-68 Caravel 26 10-05-2016 03:27 PM
How do I remove the belly pan? aluminitus Belly Pans & Banana Wraps 19 10-21-2014 10:50 AM
Belly Pan replacement canoeman Repairing/Replacing Floor &/or Frame 2 02-10-2012 02:37 PM
Bumper, Belly Pan and Banana Wrap Repair DKAir Exterior Restoration Forum 0 06-15-2011 05:51 PM
which aluminum sheet for belly pan???? clipperguy Belly Pans & Banana Wraps 2 04-26-2011 05:21 PM
