Old 05-20-2016, 06:46 PM   #1
Fullerton , North Dakota
Bed struts
We just got a new mattress. It is heavier than our last one and now the bed is really hard to lift to access the under bed storage. Has anyone found better lift struts that make lifting easier?
LWinters is offline   Reply With Quote
Old 05-20-2016, 07:37 PM   #2
2016 22' Sport
Clinton , Montana
I would suggest going to Amazon and finding replacement struts for the heavier load. Take you physical dim....ie your length and you can buy replacements. I just installed struts under my bed and two 45 lb struts will get it up but not keep it up. I've got a new heavier set coming. Believe the combined weight is about 20 lbs heavier. Look for Gas Struts.
Rpatrick16 is offline   Reply With Quote
Old 05-21-2016, 07:13 PM   #3
Bed Struts
Thanks for the suggestions. What we ended up doing...after removing the original struts, we moved both the top and bottom bracket 12" toward the end of the bed. It doesn't lift quite as high...but still very usable space and it is so much easier to lift. We then added a strap and I can lift it with one arm (and I am not real strong). If the heavier brackets don't do the trick for you...you may want to try moving the struts.
Old 05-21-2016, 07:24 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
My bed does not lift up. Seems like a lot of wasted space under it. Has anyone ever added hinges and struts to a non lifting bed?
MICHAEL
Old 05-21-2016, 08:12 PM   #5
2016 22' Sport
Clinton , Montana
There is a lot of info on the forum about doing this. For starters check out this thread. Although it covers a number of topics bed struts are one of them.http://www.airforums.com/forums/f295...-137731-2.html
I just recently added them to mine.
Old 05-21-2016, 08:24 PM   #6
AWCHIEF's Avatar
Images: 33
Thank you
MICHAEL
Gas spring struts for mattress lift RLS General Interior Topics 5 04-10-2018 09:28 PM
bed storage gas struts "stuck" gbelcastro General Repair Forum 10 08-04-2013 09:25 PM
Front to Back Struts beyond Repairing/Replacing Floor &/or Frame 5 01-01-2010 07:34 AM
Lift struts for access to under bed storage... Phil/Edee General Interior Topics 8 10-02-2008 01:43 PM
Gas assist struts for lifting bed to access storage. Phil/Edee General Interior Topics 13 09-27-2007 10:12 AM
