Old 08-02-2013, 06:18 PM   #1
2012 25' FB Flying Cloud
Gainesville , Virginia
bed storage gas struts "stuck"
Our 2012 Flying Cloud is equipped with the popular ML 16-90 gas struts to hold up the bed platform while reaching the under-bed storage. After a long first season, the struts (both of them!) decided that they won't close. I can see how one strut can break down but both at the same time? So we ordered replacement struts and guess what, the same problem. We turn, twist, push and shove them but nothing happens. The struts remain expanded i.e. won't close.
What is the trick? Where are we failing? Hope to hear from you, G&R
gbelcastro is offline   Reply With Quote
Old 08-02-2013, 07:53 PM   #2
2007 25' Safari FB SE
Suburbia , Sunny So Cal
My struts on our 2007 did that. I unscrewed them from the bed bottom and promptly forgot about it.
Several years later Uwe of Area 63 was installing a moho battery under the bed and I told him what happened. He re screwed them to the bed and using body weight closed it.
I suspect you like I just didn't expend enough oomph into closing it.
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 08-02-2013, 09:14 PM   #3
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
We have a similar issue in our 2011 International. It doesn't help that the plywood bed base flexes a bit when you're trying to close it up, but just go for it' give it a bit of weight and it'll close OK.
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 08-02-2013, 09:48 PM   #4
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, if the struts are that hard to collapse, they must be too strong. They have several sizes and pound ratings, buy weaker ones. Example: 80 lbs instead of 100 lbs.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-03-2013, 12:29 AM   #5
Scott J-24's Avatar
2009 27' FB International
Los Angeles , California
Yup, what they all said! I had the same problem when we first got our AS and thought the struts were stuck. I called the PO and he said to just use more weight and it would close just fine. He was correct. The problem went away completely when we replaced the thin trailer queen bed with a REAL full sized queen mattress from Costco.
Scott, Becky & Heidi (our standard poodle and travel companion)
WBCCI #1215
Air #54601
Remember... No matter where you go, there you are...
2009 27FB International Ocean Breeze
2010 Toyota Tundra CrewMax, 5.7L V8, 4x4
Scott J-24 is offline   Reply With Quote
Old 08-04-2013, 09:08 PM   #6
dznf0g's Avatar
Oswego , Illinois
Also, whenever these struts are installed, they must have the oil filled black tube "up" and the silver rod "down" so that the seals will stay lubricated and slide easily....and not dry out.
Now with a bed...one could argue that they are horizontal most of the time and only extended once in awhile, so it shouldn't matter.
BUT, I found that mine were installed upside down and were sticky. Further, after careful study, I found they weren't horizontal when the bed was closed. They were tipped to the "butt" or black end when closed and , of course "butt" or black end down when the bed was open.
I reversed them and have had no further issue.
-Rich-
Old 08-04-2013, 09:18 PM   #7
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
So...what did you do? Did you drive around with the bed at a 45 degree angle?
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 08-04-2013, 09:19 PM   #8
dznf0g's Avatar
Oswego , Illinois
No, I reversed the mounting position, so the black tube is toward the head of the bed.
-Rich-
Old 08-04-2013, 09:20 PM   #9
dznf0g's Avatar
Oswego , Illinois
Mine weren't frozen.....just sticky.
-Rich-
Old 08-04-2013, 09:24 PM   #10
m.hony's Avatar
2013 30' Classic
I was asking the op. I guess I should have specified.
TAC #MS-10
Airforums #70955
Old 08-04-2013, 09:25 PM   #11
dznf0g's Avatar
Oswego , Illinois
sorry, carry on.
-Rich-
