Old 08-18-2013, 07:40 PM   #29
Glamper Girl
silverwheels's Avatar
2008 23' International
Sunny San Diego , California
Got her up and running! Yay!!!
Glamper Girl
silverwheels is offline   Reply With Quote
Old 08-18-2013, 07:49 PM   #30
SilverGate's Avatar
2007 23' Safari SE
Yay!!! Congratulations!
SilverGate is offline   Reply With Quote
Old 08-18-2013, 07:59 PM   #31
Glamper Girl
Im so excited!!! Have a question ..... does your tv work when u r boondocking?
Glamper Girl
Old 08-18-2013, 08:18 PM   #32
SilverGate's Avatar
2007 23' Safari SE
Our 2007 Safari's TV works fine for watching DVDs while doing non-hook-up camping because we have a 600 watt inverter that came with the trailer when it was built. But to see the digital channels of today, I would need to have a converter box installed. I have not done so because we feel no need to watch TV programs while camping... we would rather conserve our batteries by listening to the radio and our local KPBS-FM's wonderful programs!
Old 08-20-2013, 05:48 PM   #33
Glamper Girl
tv
Really? I know my rig comes with an inverter but my tv doesnt work? any thoughts?
Old 08-20-2013, 06:16 PM   #34
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
not the expert here. but if you have a older tube tv might be too much for 600 watter to handle.. the newer digital tv use only like 1.2 amps which is some 253 watts. guess also depends on battery cap etc..
just throwing out ideas.
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 08-20-2013, 10:49 PM   #35
SilverGate's Avatar
2007 23' Safari SE
Yes! Since this is a "new-to-you" trailer, you may not know that when you are "boondocking" and want to watch the TV, you need to unplug the TV from the regular AC receptacle and plug it into the nearby "Inverter Circuit" receptacle with the the blue label indicating 'Inverter Circuit". Then go over to your galley and under the Systems Monitor and other receptacles is the Inverter Switch (a "Push On/Off" button) that needs to be turned On to power your inverter.... then turn on your TV. (Don't forget to turn off the inverter when done watching the TV and monitor your battery frequently while "boondocking".)
You also might want to check to see if your inverter is large enough for your TV.
Old 08-21-2013, 01:36 PM   #36
SilverGate's Avatar
2007 23' Safari SE
Photos of the Inverter Circuit receptacle & Switch
Originally Posted by SilverGate View Post
Yes! Since this is a "new-to-you" trailer, you may not know that when you are "boondocking" and want to watch the TV, you need to unplug the TV from the regular AC receptacle and plug it into the nearby "Inverter Circuit" receptacle with the the blue label indicating "Inverter Circuit". Then go over to your galley and under the Systems Monitor and other receptacles is the Inverter Switch (a "Push On/Off" button) that needs to be turned On to power your inverter.... then turn on your TV. (Don't forget to turn off the inverter when done watching the TV and monitor your battery frequently while "boondocking".)
In the photos below, you will see that our TV is plugged into the regular AC receptacle [when using while on shore power] and that the Inverter Circuit receptacle is labeled and on the right side.
By the galley in our 2007 23' Safari are our monitors, and at the bottom is the Inverter Switch (shown as a close-up in the last photo).
Name:	DSC_0055 Inverter circuit receptacle.jpg
ID:	193760   Click image for larger version
Name:	DSC_0061 Monitors & Inverter switch.jpg
Name:	DSC_0058 Inverter switch.jpg
Old 08-22-2013, 12:49 PM   #37
Glamper Girl
Thanks for the pics!! You made my life easy. I know my handbook says my rig comes with an inverter but I don't see one anywhere. I'm probably goin to call airstream to confirm my model has one and where it may be.
Once again you have been more than helpful! You rock!!
Glamper Girl
Old 08-22-2013, 01:17 PM   #38
SilverGate's Avatar
2007 23' Safari SE
Where our inverter is located
Are you sure your handbook says you have an inverter (or does it actually say "converter", which all trailers have). My Owners Manual does not list "inverter" in its index because it is an optional item.
I did find our inverter years ago by removing the street-side front lounge cushions, which revealed a hole, and forward of the hole is a "secret trap door", and upon lifting it, revealed our 600-watt Sine Wave Inverter made by WFCO.
See post #281 & 282 of SilverGate's Safari is Home at Last!
Also see this thread: "What is an inverter?"
Name:	HPIM1388 Trap Door Opened & Inverter.jpg
Old 08-22-2013, 01:54 PM   #39
Glamper Girl
And there lies the problem!! I confused inverter with converter!! Haha I'm a newbie can you tell?
Thanks for all your help silver gate!!
Glamper Girl
Old 08-22-2013, 02:02 PM   #40
SilverGate's Avatar
2007 23' Safari SE
You're very welcome, silverwheels, and welcome to the wonderful world of Airstreaming!
Bill
(And that was a nice way to make my one thousandth post!)
Old 08-23-2013, 01:18 PM   #41
SilverGate's Avatar
2007 23' Safari SE
Now... where were we? Oh yes...
Hi Silverwheels,
Last Wednesday, Abe (RV Mobile Service 2U) came out and cleaned and repacked our bearings, and cleaned, inspected and adjusted our brakes.
We were very impressed with his knowledge, experience, and work.
More about this in "Getting my bearings... repacked", post #523 of "SilverGate's Safari is Home at Last!" thread.
Name:	DSC_0041 Repacked bearings.jpg
ID:	193930   Click image for larger version
Name:	DSC_0042 Bearing grease packer.jpg
Name:	DSC_0043 grease seal.jpg
Transforming a '59 Tradewind epperp 1959-69 Tradewind 49 03-30-2015 09:45 AM
Need to Know where I can buy wheel bearings and seals for a '73 Argosy VonLuck Wheels, Hubs & Bearings 14 07-04-2011 09:22 PM
When do I repack bearings? Silver Otter Wheels, Hubs & Bearings 2 06-15-2011 12:16 PM
