Old 05-08-2009, 02:37 PM   #1
kayamtom's Avatar
Oxford , Oxon
Bearing Pre-load
Hello
I am repacking the bearings on my 1962 Overlander and am wondering what torque load (if any) to apply to the locking nut?
The trailer has the 12x2 brakes if that is important.
Many Many Thanks
t
kayamtom is offline   Reply With Quote
Old 05-08-2009, 03:24 PM   #2
1972 Travelux Princess 25
Cobourg , Ontario
They don't need any preload. The correct method is to tighten the center nut and give the wheel a spin. This squishes the grease out of the bearing. Then back off and tighten it again, barely snug, and back off just enough to get the cotter pin in.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 05-08-2009, 03:34 PM   #3
Originally Posted by kayamtom View Post
Hello
Many Many Thanks
t
Did you replace the grease seals?
If not, your taking a huge gamble.
If you did, great PM.
Old 05-08-2009, 03:41 PM   #4
Images: 59
I think you should torque the nut to 40-50 ft-lbs to seat the races, then back it off completely. Retighten finger tight, back off to the nearest hole and insert the cotter pin.
Old 05-08-2009, 03:57 PM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
Unless you replaced a bearing the races should be seated by now.
While spinning the drum I use a pair of channel lock pliers and tighten down on the castle nut. Not too hard just good and snug. Back off about a half turn and then again tighten while spinning. Note the position of the castle nut slots with respect to the cotter pin hole and back the nut off to the next hole. You should be able to feel some free end play in the drum when done.
Better a bit loose than a bit tight.
2004 Excursion 4x4
Old 05-08-2009, 04:03 PM   #6
Hello
Many Many Thanks
t
Ths is the bearing information from the Henschen Service and Maintenance manual.
Click on the article to enlarge it.
Old 05-08-2009, 05:09 PM   #7
kayamtom's Avatar
Oxford , Oxon
Hello again,
Super Speedy and informative responses. I like it. Thanks for your time.
I have new bearings races and seals so there is a whole lotta lurve going back into trailer. I even have some blue grease!
So the thing to do is wind the nuts up to the 40/50 lbs for the races and then wind he drum back and forth and ease off the nut to find that little bit o play?
Thanks again and kind regards
tom
Old 05-08-2009, 05:42 PM   #8
HowieE's Avatar
Images: 12
If you are setting new bearings make sure you have cleaned the areas of the hub that the bears seat in. Cleaning the stop face is most important as any debris may cause the race to be tilted in the hub.
2004 Excursion 4x4
1/2 ton tires- load C to load E John Tires 75 03-20-2009 09:15 AM
Pre-wire in 27FB gowyn Audio, Video & TV 3 05-28-2008 11:32 PM
Load bearing or not load bearing? Petethefeet Ribs, Skins & Rivets 3 04-27-2008 07:36 AM
pre fab showers available? Tidal Sinks, Showers & Toilets 4 06-14-2007 08:14 PM
pre 1993 whats better? vagabonds Our Community 0 03-22-2002 07:09 AM
