Old 06-03-2014, 05:40 AM   #1
1965 26' Overlander
Ogunquit , Maine
Bay Breeze A/C Question
I have the original Bay Breeze A/C in my 1965 Overlander which works great with one exception. It has be oiled and services recently but I am having an issue with the fan suddenly stopping. It runs great, cools fast and the compressor kicks on and off fine. The fan will mysteriously shut down and refuse to kick back in when the compressor signs on after it has been running for a good bit if time. I have to shut it all down, wait about an hour and then the fan is fine. Does anyone have a clue as to what cold be causing this? Thanks, Dom
dominicjohn is offline   Reply With Quote
Old 06-03-2014, 07:43 AM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
First guess is that the fan motor is overheating or the thermal overload switch thinks it is overheating.
If the bushings are tight and the fan does not turn totally free, the overheat would make sense.
Old 06-03-2014, 11:22 AM   #3
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
You didn't change thermostats by chance did you?
I tried to wire both low and high fan through my thermostat and the thermostat wanted to run both at once.
After two or three minutes, the fan motor would overheat and stop running.
I wired high and low through a double pole switch instead.
Bay Area Airstream Dealer (San Francisco Bay Area) AdamB Our Community 25 07-16-2013 05:29 PM
Armstrong Bay Breeze Air Conditioner CJ of Okla Furnaces, Heaters, Fireplaces & Air Conditioning 2 05-05-2007 07:38 PM
Bay breeze airconditioner yaakman 1965 Safari 2 04-04-2006 09:47 PM
