Old 10-07-2014, 01:52 PM   #1
Twinkiemand's Avatar
2014 28' International
Fort Riley , Kansas
Battery life is dismal at 9 months after buying new
Hi fellow Airstreamers,
We are fairly new owners and have had the opportunity to travel with our trailer. We bought the 2014 International serenity and are very, very happy with it. That is if we can figure out what's eating our batteries?!
Here's what's been happening:
We store our rig at the storage facility, concrete pad and level. When we store it, we turn the main storage switch to off (inside the trailer) and to the best of our knowledge nothing else is running (other than what we have been told the inverter and carbon monoxide detectors).
So in the beginning of September we went about 5 hours drive to Omaha and I wanted to turn on the fridge, only to find that the batteries were depleted. At that point the trailer had been parked since the beginning of July, roughly 2 months. This was a pretty long time as we were moving , so I figured oh well, we ran out because we didn't use it. I hooked up a generator to revive the batts, was able to run the fridge for 24 hours and it got nice and cold. Then we left and towed to Omaha where we were hooked up to shore power for 3 days and nights. When we left the campground the status showed us 100% battery, but when we returned the Airstream to the lot about 6 hours later, the status panel stated that all we had left was roughly 75% of power. I thought that was strange, because isn't the truck charging the batteries while we are driving? So again, we parked and put the rig into storage mode.
About two weeks later I went to clean the rig a bit and found that the batteries were all but depleted, the LED lights insight didn't even shine bright but dimmed all the way to a flicker. So I checked the batteries (interstate deep cycles, stock) and made sure they had enough water, check. So hubby and I took the batts to the nearest auto parts store to get them checked and they were all empty, so they charged them, checked them and gave us the green light for functionality. So now we are not sure what to do next, how to figure out the issue and here are some of my questions:
1. Is it common that the rigs run out of battery super fast during storage or shouldn't they hold a charge longer? I mean I could never go boondocking like this, we'd be out of juice instantly.
2. Is it smart to install one of those battery shut off's in the back between the main power line and the batteries, and if so, can we do that ourselves?
3. Shouldn't the truck charge the airstream while driving?
4. We bought a battery tender to keep the batteries good to go, but I would prefer not to have to take them out all the time, or should we?
Thank you so very much for your help, I am really trying to figure this out and I cannot just jot on over to the Airstream dealer as we are about 6 hours from the nearest one.
Dunja
The trouble is, you think you have time. ~Buddha
Twinkiemand is offline   Reply With Quote
Old 10-07-2014, 02:04 PM   #2
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
I would think that the board in the fridge, by merely being connected to the system, would draw some juice, don't know how much. Perhaps something else is also using some electricity while stored.
I would suggest that you install a solar panel and controller to keep the batteries charged while in storage. Then, if you decide to do a lot of boondocking, you can add panels until you run out of room on the roof to add them. I installed solar on both trailers and all batteries remain charged, no matter how long in storage.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 10-07-2014, 02:21 PM   #3
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
It should charge while you are driving if the batteries are not already toast from overcharging as mine were.I had to replace my converter ($200) from Randy at Best Converters.Takes about one hour too switch.
My factory converter was cheap junk and ruined the batteries in one season.
Moflash is online now   Reply With Quote
Old 10-07-2014, 02:31 PM   #4
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
A solar panel will work, but it's expensive - and if you're in covered storage - it's useless.
If your batteries become totally discharged or close they may be sulfated and ruined. Do you know the birth date of your 2014? It might have been manufactured in middle to late 2013. It is quite possible that your batteries were over a year old when you bought your unit... and dealers probably don't take great care of them. Even if your batteries are over 2 years old, they've still worn out rather quickly.
There can be a lot of phantom draws, though turning the switch to "store" should cut out most of them. The "store" setting is really designed for a week or two. If you're putting the Airstream to bed for the winter, or for several months, it's best to take the batteries out and store them in a cool dry place.
There are also many threads about three stage battery chargers which do a better job. They don't overcharge the batteries which shortens their lifespan. You might want to do a SEARCH on that to get more details. Not terribly expensive, couple of hundred.
Of course the very best fix would be to use it every weekend.
I live in mine full time. (Your mileage may vary.... One size does not fit all... This advice is worth what you paid for it...) I've gotten about almost 4 years out of standard factory batteries, and when I boondock I used to carry a very small generator and charger just in case the batteries wore down, but the new Eddie Bauer has solar so that's become somewhat redundant. There are many options and some of the other ones might be better if you aren't using your unit frequently.
Hope this has helped somewhat.
Paula
Old 10-07-2014, 02:41 PM   #5
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
Also keep in mind if you are connected to shore power the monitor will show the voltage coming from the converter and not the battery voltage. It is possible to see 100% on the monitor with the batteries actually less than 100%.
Landrum is offline   Reply With Quote
Old 10-07-2014, 02:54 PM   #6
Fort Riley , Kansas
We actually checked the panel after hooking off from shore power, about 10 min or so after. Then again when we stored and it was at three quarters. I am never really sure how reliable that panel is, it also showed our black tank on green status when we were already backing up, visibly. Yikes. Thank you for your input!
Old 10-07-2014, 02:57 PM   #7
Fort Riley , Kansas
How do I know if the batteries overcharged? All I really know how to do is to make sure the diodes are always covered with distilled water. And would the converter not be under warranty? We bought new 10 months ago. So one season is all you got out of your batteries? Which ones did you buy after?
Old 10-07-2014, 03:00 PM   #8
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Shouldn't the only things draining the batteries when the Store/Use switch is on Store the LP leak detector and the Store/Use switch? I would think it would take several months or more for 2 fully charged batteries in parallel to be drawn down even to 50% (about 12v). The LP leak detector should only draw 120mA according to Atwood's specs. When I'm in store mode nothing connected to the 12v circuit panel will turn on I would think I could leave the AS in storage with the Store/Use switch on Store for 6 months. I've started to disconnect my negative battery lead when I put my AS in storage even for less than a month.
How many volts and what amps does the tow vehicle generate at the 12v lead on the 7 pin plug with driving at 60mph or if the engine is running 1500 to 2000 rpm? Charging two depleted batteries by the car should take more than a days driving I would think.
Kelvin
KJRitchie is online now   Reply With Quote
Old 10-07-2014, 03:04 PM   #9
dznf0g's Avatar
Oswego , Illinois
Kelvin,
I checked recently. Although TVs will be different, a 2013 Silverado 2500hd (at idle) delivers 12 - 13 amps. Items onboard the AS were consuming about 2.5 amps of that for a net effective charging rate at 10 - 10.5 amps.
-Rich-
Old 10-07-2014, 03:04 PM   #10
Fort Riley , Kansas
Paula
Hi Paula,
I am not real sure about Silver Girl's birth date, we bought her and we had to store at the dealer for 6 months before picking up, due to my hubby's overseas deployment. When we picked the Airstream up we got the low down on how to take care of it somewhat, but no one at all ever even mentioned the battery water issue. I was told that over the phone when I called about a week ago to ask what the problem could be. So I rushed over to check and luckily it was fine and water covered. THe load test at the Auto parts store came back all good as well, doesn't that mean that my batteries are fine and are loading fully? I just don't want to buy new batteries when the real issue is something else. While at the auto store this weekend we purchased a Deltran Battery Tender Plus to charge our batts during the winter, without the danger of overload.
Dunja
Old 10-07-2014, 03:10 PM   #11
Fort Riley , Kansas
Kelvin
Kelvin,
I'm not even sure what the output is on the truck we have, its a Ford F150 Ecoboost. The day we drove we were out there about 6 hours, median speed at around 60 mph.Also, when we left the batteries were fully charged from being hooked up to shore power.
Dunja
Old 10-07-2014, 03:14 PM   #12
Fort Riley , Kansas
Also, if you are hooked up to shore power, do you turn any switches in the Airstream off?
Old 10-07-2014, 03:20 PM   #13
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
If you have a propane detector, it is typically wired to the battery side of the shutoff switch (at least on my trailer) and therefore draws current all the time. It takes about 1/4 amp. I don't know what batteries you have, but if two Group 27s that is around 160 AH. The propane detector will use 6AH per day, so that will deplete the batteries in about 26 days. If this happens and a load remains on a dead battery for a long time, it can damage or kill the battery. Also, repeated full discharge will damage a battery. A goal would be to discharge the batteries to no more than 50% most of the time.
Auto and boat parts places sell a cutoff switch that mounts right on a battery terminal. You just take whatever is on the terminal off and mount the switch and then put what was on the terminal on the switch. I plan to put one on my trailer, but for the time being I just disconnect the negative battery cable (I only have one battery). Why the negative you ask? If you slip with a wrench and hit any part of the trailer structure while loosening the positive and the negative is still connected, you have shorted the battery and high energy bad things happen. If you do the same thing on the negative, no problem, the other end of the cable is connected to the structure.
You can get an inexpensive multimeter at Lowes, Home Depot, or many other stores. I prefer an analog (needle indicator) vs. digital (numeric display). To look for phantom current drains:
1. Disconnect the negative cable
2. Put the multimeter in DC current (amps) mode on the highest scale available . This is sometimes indicated by a solid line with a dashed line over it on the selector switch and Amps (A) are more than milliamps (mA), 200mA = 0.2A.
3. Connect the positive meter lead to the cable that was on the battery and put the negative (common, minus) lead to the battery post and read the current.
If anything other than zero is indicated, you have something drawing current. Check storage compartments for lights that accidentally got turned on, make sure the refrigerator is turned off, etc. until you get the current as low as possible with zero being ideal.
You can use the example above to figure out how long your batteries should last once you know the parasitic current drain. That said, batteries start out with a pretty low internal drain, but as they age, it gets higher. Wet cell lead acid batteries will sometimes shed lead particles that pile up in the bottom of the cells. This is made worse by shock and vibration. When they reach the bottom of the plates, leakage current goes way up and the batteries won't hold a charge very long at all. Regarding your TV charging the batteries, I have read that the TV usually can only source about 7A. So if you have 160 AH of batteries, it would take 23 hours or more to charge them up to full from zero.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Al and Missy is online now   Reply With Quote
Old 10-07-2014, 03:31 PM   #14
Fort Riley , Kansas
Al
Hi Al,
first off, thank you so much for your thorough reply. I do sometimes feel like the total newbie I am and any advice really helps. We have two 24 deep cycle Interstates, that's the largest that will fit without modification of the battery compartment. I try not to have the batteries empty, but it seems with the way things are going there really is nothing I could do. We are thinking of purchasing a battery-off switch, but we waited as we wanted to make sure that it is not something related to the Airstream. Thank you for your tip on disconnected the negative vs. the positive side, good to know for sure! I will see that I can buy one of the Amp meters and try your suggestion. Also, I never turned the fridge off per se, I only turned off the power by putting it into storage mode. Was I supposed to turn the fridge off before switching into storage mode? I thought once I do that everything is turned off automatically including the two TV's? Should I unplug the TV's? How confusing lol.
Dunja
Battery charge rate after sitting 6 months idroba Batteries, Univolts, Converters & Inverters 4 04-09-2013 02:58 PM
investigating RV life, after getting wiped out innjtown Member Introductions 22 05-10-2008 11:10 PM
First two months in our new 23' Safari SE LS OrangeKid 2007 Safari SE 5 03-28-2007 01:20 PM
**Life After An Airstream** Silvertwinky Our Community 23 07-11-2005 01:10 PM
Six whole months Pahaska Our Community 3 12-02-2002 08:44 AM
