Old 07-09-2015, 12:35 AM   #1
2008 25' Safari SS SE
Olympia , Washington
battery box corroded out, needs to be replaced
Greetings all. Helping my brothers widow increase her comfy taking out their safari 25. Discovered pitting and other corrosion holes in the bottom of the battery box. Looks like it shouldl be replaced. Curious what others have done about this. The batteries were new last year. Something plastic, diamond metal
O
Chris mccord is offline   Reply With Quote
Old 07-09-2015, 07:17 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
My battery box has a plastic or hard rubber tray. I do not know if it is OEM or installed by the previous owner.
MICHAEL
Old 07-09-2015, 07:33 AM   #3
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Depending on how bad it is you can restore is. Mine had one small hole and some rust. I sanded mine and used a wire wheel brush to clean it. Then I used Ospho Rust Treatment which turns rust back to metal via chemical change. After that, I coated the whole thing in POR-15. Rust shouldn't be a problem anymore.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
I have 3 boxes of assorted parts from my airstream 59 Tradewind, I would like to sell by the box for 300.00 per box or best offer per box betsy Airstream Classifieds 0 09-19-2014 11:01 AM
Corroded Burner BambiII'64 Water Heaters, Filters & Pumps 3 03-05-2008 08:40 PM
Shower Drain Corroded Moonstruck Sinks, Showers & Toilets 2 08-13-2007 02:33 AM
locks for battery box and propane box Chilao Doors & Locks 11 11-02-2004 06:56 PM
removing corroded belly pan screws Cruiser Belly Pans & Banana Wraps 2 09-14-2003 12:17 PM
