Old 06-10-2015, 11:48 AM   #15
Gainesville , Florida
Yes the deep cycle not the starting battery. Jim
Old 06-10-2015, 11:49 AM   #16
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Originally Posted by Gearheart View Post
Exactly. Now think about this. How long, even considering replacing the $61 battery every 3 years, (I get 5 years out of mine) before the expense starts to approach the cost of lithium batteries? Do lithium batteries last that long? Are they really worth it? As stated above, you must also totally re-configure your charging system. Add that cost in also.
BTW you do not want the marine starting MS battery. You want the marine deep cycle one.
Thank you Gearhart - my thoughts exactly. We sometimes forget we can OVER think "emergency readiness". Dead batteries - at a rally with no hookups. Unhitch, pull the dead cells, run to town, buy 2 deep cycle ones, plop them in, and smile. Duh.
Paula
Old 06-10-2015, 12:12 PM   #17
Amsterdamer's Avatar
2015 27' Flying Cloud
Caledonia , Michigan
I went with Interstate Marine grade deep cycle AGM batteries in our new unit. They do not vent and water does not have to be added. A pair of Marine grad AGMs are more expensive than the normal wet cell batteries, but less than Lithium. The charger in your camper should also work fine with AGM batteries. Interstate claims three times the life over flooded batteries for their AGMs. I’ve had good luck with AGM in my motorcycle and truck.
Amsterdamer is offline   Reply With Quote
Old 06-10-2015, 12:25 PM   #18
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by Amsterdamer View Post
I went with Interstate Marine grade deep cycle AGM batteries in our new unit. They do not vent and water does not have to be added. A pair of Marine grad AGMs are more expensive than the normal wet cell batteries, but less than Lithium. The charger in your camper should also work fine with AGM batteries. Interstate claims three times the life over flooded batteries for their AGMs. Iíve had good luck with AGM in my motorcycle and truck.
Actually, the OEM Parallax converter with its constant voltage charging will ruin an AGM battery in short order. ALL lead based batteries, and especially AGM types require 3 stage charging at specific voltages determined by the battery manufacturer.
A steady 13.6 VDC from your P/lax WILL either under charge or overcharge any lead acid battery.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 06-10-2015, 12:46 PM   #19
jayseejay's Avatar
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach , Florida
Lew or others,
I understand from prior threads that there is at least one nearly exact replacement 3-stage converter to replace the Parallax single stage converter used in current 30Amp Airstreams. I have a 50amp unit - is there an available upgrade that a non-expert can install for 50amp configurations, or is it more complicated than that? Thanks in advance for any suggestions.
Best,
Joe
jayseejay is online now   Reply With Quote
Old 06-10-2015, 02:12 PM   #20
1967 26' Overlander
Spartanburg , South Carolina
My vintage trailer has little in the way of parasite drag so the folks with newer rigs might give better advice that me. Having said that, I am 5 years into an Optima AGM battery that is kept charged with an Intellipower converter. It has not to date shown any sign of weakness. I know it is charged every time I hook up because I operate the tongue jack on battery to be sure. The AGM batteries never require water and you don't have to worry about acid splashing out if you hit a bad patch of road. They are pretty rugged batteries and mine seem to charge fairly quickly, though I seldom run them completely down.
Jacob D is offline   Reply With Quote
Old 06-10-2015, 02:53 PM   #21
lewster's Avatar
Originally Posted by jayseejay View Post
Lew or others,
Best,
Joe
Progressive Dynamics 4655 replaces the 30 amp power center converters. For a deck mount used in the 50 amp units, use the PD 9260.
There is a nice thread somewhere detailing the DC fuse block conversion too.
Lew Farber
541-490-6357
Old 06-10-2015, 03:15 PM   #22
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
If you bought it from a dealer just a few weeks ago, I'd call them first. It must have come with some sort of warranty- 30 or 90 days even. The worst they can do is say no, and it only cost you a phone call.
2012 Dodge Durango Hemi/AWD
Old 06-10-2015, 06:46 PM   #23
2014 23' International
Lehi , Utah
Can anyone tell me if the Costco 24DC pictured below is the same as the Interstate SRM-24.
RaymondFitz is offline   Reply With Quote
Old 06-10-2015, 07:43 PM   #24
St Paul , MN
Good advice! My experience at dealership is to acknowledge it was sold as is and to ask 'if they can help you out' with a new battery.
The cost of a new battery is small price for customer retention. They likely have one in stock or could get you one at cost.
If a battery is the only thing on your service checklist you did well at the dealership!
Seemore2006 is offline   Reply With Quote
Running Lights don't work, Other exterior lights work jrvly1976 Lights - Interior & Exterior 15 01-27-2015 09:27 PM
Vent Wiring in '56-ish InsideOut 1956 Safari 8 09-27-2009 06:36 AM
Single axle Airstream, 1975 ish Apache_Camp Trailer Values 4 07-28-2009 10:55 PM
New(-ish) fridge n/w on AC (Hi So Cal friends!) grantb4 Refrigerators 0 07-23-2006 02:47 PM
New(ish) interior for 75 Argosy 3Ms75Argosy General Interior Topics 1 08-16-2004 01:54 AM
