Old 05-28-2016, 12:14 PM   #1
2003 28' Classic
Ladysmith , Wisconsin
Bathroom water pump switch broke ?
We have a 2003 28' Classic. The water pump switch in the bathroom is acting broke. Used to be able to turn off and on the water pump with either he range hood water pump switch or the bathroom water pump switch. Both Switches were independent of each other. Now the batjroom water pump switch does not turn on the water pump. Instead, the range hood water pump switch must be set to on. Funny that I can turn off water pump still from bathroom with a flip of switch. Just cannot turn on the water pump from the bathroom. Going to reloads switch
JacobMerridy is offline   Reply With Quote
Old 05-28-2016, 10:37 PM   #2
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
This is how those two switches work to control the pump.
http://electricaltechnology.org/wp-c...gspot.com_.jpg
Old 05-30-2016, 06:28 AM   #3
2003 28' Classic
Thank you
Appreciate your effort. I ordered a new switch and I'll see if this corrects the issue.
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 06:46 PM
Bathroom Water Pump Switch? Al and Missy Fresh Water Systems 9 03-06-2014 08:27 AM
Water Pump Switch roadtrip07 Water Heaters, Filters & Pumps 17 10-11-2010 05:07 PM
Water Pump and switch wacnstac Water Heaters, Filters & Pumps 2 07-25-2010 01:00 PM
water pump switch wheel interested Water Heaters, Filters & Pumps 1 12-11-2003 09:46 PM
