Old 06-27-2016, 03:33 PM   #1
Rus
1996 21' Sovereign
Winston-Salem , North Carolina
Bath vent removal
Hello all.
I'm attempting to replace the round bath - (push to open) vent on my 1996 21' Sovereign. It's been a bear - the bear thus far is prevailing. Following A/S manual has gone smoothly enough thus far. Problem is their is a lot of caulk on the inside skin that seemingly will not allow vent to be removed thru outer layer (exterior) of aluminum skin; it appears the caulk was used in order to give a bed to the screws as rivets were not used. Access to interior side of outer skin is limited thru the interior skin where vent screen/trim was removed. Grateful for suggestions or experience.
"Rusty"
Rus is offline   Reply With Quote
Old 06-27-2016, 07:35 PM   #2
RV DEALER IN COCOA FL
1987 32' Excella
cocoa , Florida
It's not caulk. Most likely it butyl. I just did mine 2 days ago. Make sure all screws are removed from the top then work around the vent prying it away from the roof skin.
juvaro2002 is offline   Reply With Quote
Center bath or rear bath Sovereign? desertratt General Repair Forum 9 09-24-2011 09:40 PM
Converting Rear Bath To Side Bath musicmaster Waste Systems, Tanks & Totes 17 12-04-2010 02:39 PM
want to trade center bath for rear bath? nomader General Repair Forum 7 02-23-2010 05:40 PM
Move a rear bath to a side bath? rjacques General Repair Forum 11 12-27-2008 10:25 PM
Has anyone ever converted a regular rear bath to a wet bath? tvadman1963 Sinks, Showers & Toilets 2 12-29-2006 11:15 AM
