Old 05-12-2009, 06:18 AM   #15
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 202
I did a '72 Overlander 5 years ago and took a few pictures.
I had to remove the bedroom walls (both sides) and replaced the entire sheet of plywood after "freshening" up the frame a bit. The black water tank supports and box needed replacement/refurbishment.
Here are some pics I took.
Good luck!
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 05-12-2009, 02:07 PM   #16
Arrowstream's Avatar
Columbia , South Carolina
Rivet, rivet... I liked the part where you drill out a bunch of rivets to remove the trim strips so that you can access a couple hundred more rivets to dismantle the bath fixture pieces parts! I'm glad that the bath is in the back/last to take out, because I might have quit if it was the first thing that I tackled. But it's all out now. The floor rot that I found under the kitchen DWV pipe had nothing on the floor rot under the rear/tub DWV pipe. I had assumed that it would need to be replaces anyway, with all the rot, it'll be easier to remove. Keep plugging, we'll get there.
Arrowstream is offline   Reply With Quote
Old 05-13-2009, 05:54 AM   #17
1969 31' Sovereign
1951 21' Flying Cloud
Alex , Oklahoma
Frame sag
Originally Posted by Steve Tryon View Post
Hey my 69 sovereign's bathroom is all over the driveway right now. Rotten plywood Did you have any frame sag or repair to do? I have some rusted out frame.
Steve yes we had the frame sag, but were luck only a small rust out on frame. Feel free to private email us.
1969 Sovereign
1951 Flying Cloud SS#7062
AIR #18751
CJ of Okla is offline   Reply With Quote
Old 05-20-2009, 07:03 AM   #18
1969 27' Overlander
Lehi , Utah
I guess there comes a day in a new Airstream owners life when they have to quit doing research, stop gathering tools and chargeing batteries, grab a drill and start tearing things out. Yesterday was that day.
When I dropped my belly pan I found that my waste tank box had pretty much dissolved, I hope I can figure out exactly where that needs to be when I rebuild. a lot of the floor had rotted and the frame is pretty rusty. It took a bit of cheating to complete the bathroom fixture puzzle but its pretty much out.
Questions: rivets, I am going to need a million of them to put this all back together where is a good source? Do I need Clecos?I have never used them
I guess if the frame is pretty rusty just brush it off and add some reinforcement?
Mr Tubby? seems like a good product to paint the sink, tub, and toilet wrap?
Thank you so much for all of the great advise it has helped a bunch. Today I hope to finish the demolition and start the rebuild.
Thanks again
Clay
ClayC is offline   Reply With Quote
Old 05-20-2009, 11:06 AM   #19
dnrtheil's Avatar
1964 24' Tradewind
Portage , Michigan
I just ordered 200 1/8" aluminum blind rivets (these are used on the interior) from Fastenal for $6.00. Home Depot is at $4.97 for 100 of the same rivet.
Derek
Operation "SAVE RUDY" Strike Team (Associate Member)
dnrtheil is offline   Reply With Quote
Old 05-20-2009, 12:09 PM   #20
Distantdrummer's Avatar
1975 31' Sovereign
Houston , Texas
Question Both Walls ?
Ron was the wall removal BOTH SIDES necessary to remove fixtures out of the trailer? That is do you know if the tub could be removed from a 70' era rear bath with just the curbside (or just the streetside) bulkheads removed?
As I read your pictorial I am not sure you took your tub out of the trailer.
__________________________
____ d'drummer ____
...aahh..rumm..pu..tum..tummm...
Distantdrummer is offline   Reply With Quote
Old 05-20-2009, 01:55 PM   #21
As far as what needs to be removed to access all the fixtures, you never know what may have been altered over the years. I couldn't figure out the spaghetti mess of drain piping until I dropped my waste tank. Then I found that the kitchen sink, the bath sink and the shower had been plumbed to drain downstream of the black water tank and release valve. In other words, the gray water went straight out - no tanks, no valves. I don't think they let you dump gray water straight to the ground these days, so I'll have to add a tank, or plumb it back into the single tank.
Old 05-20-2009, 04:07 PM   #22
bullydogsmom's Avatar
1972 25' Tradewind
old mystic , Connecticut
Thanks again
Clay
Clay,
Sounds like you have jumped in with both feet, good for you, We have a Napa not far from us, we bought the rivets by the box of 500,make sure you get the aluninum ones, and believe me you will you that many and many more, 1/8 by 1/4 was what we used the most of on the inside. We also purchased , the one tool that was money well spent, for 105 buck we bought an air powered rivet gun. By far the best investment you'll ever make.
Post some picture of what you have found, we love pictures here, and believe me what you found under your belly pan, is the same thing most of us has found, some worse than others.
Annette
bullydogsmom is offline   Reply With Quote
Old 05-20-2009, 05:43 PM   #23
1969 27' Overlander
Lehi , Utah
Well so far I have every thing out of the bathroom from the bedroom walls back. I had to loosen the door frame on the road side bed room closet ( I have a "D" double model) in order to take the closet that covers the hot water heater. Cut out most all of the copper and drain pipes, and now comes the floor, or what is left of the floor. I have taken lots of photos and have marked every thing with blue tape. tomorrow I will start cleaning the frame underneath to see what needs to be welded before I start to reassemble.
Thanks for the riveting tips, I found that I have a Fastenall Close and I plan to look into the rivet gun.
Clay
Old 05-21-2009, 07:13 PM   #24
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
When you buy the aluminum pop rivets most have a light steel mandrel [the pin that pulls the rivet]. You may want to consider the aluminum mandrel, 0 chance of dissimilar metal corrosion. They do cost a little more. Beware of really cheap rivets and rivet guns. Often the bargin stuff breakes of the mandrel way above the rivet. Makes an otherwise enjoyable job a real P.I.T.A.!! You can order a catalog online from jay-cee sales & rivet,,, Aircraft spruce.com and others. They have tons of pics & info on rivets, aluminum and tools. For bucked rivets and aluminum work check out the thread by Aerowood,1971 Globetrotter.
putback is offline   Reply With Quote
Old 05-21-2009, 07:44 PM   #25
sequoiacoast's Avatar
1968 24' Tradewind
Eureka , California
I bought (most) of my rivets, propane tanks, stove vent cover, lights, and more here: Vintage Trailer Supply - Vintage travel trailer parts and supplies!. I would definitely steer clear of rivets with the steel mandrel.
And I bought an air rivet gun from harbor freight- cheap but still works!
Good luck and have fun!
Tanya
"If you want something done right, do it yourself!"
sequoiacoast is offline   Reply With Quote
Old 06-06-2009, 08:18 AM   #26
kmb66's Avatar
1966 26' Overlander
Thornton , Colorado
My first post! Thanks for all the helpful information. My hubby and I are tackling our rear bathroom as soon as we install our fantastic fan.
My question is, after you have completed the floor repair, what kind of tile did you put back in? It would have to have the same thickness as the asbestos tile... because when you re-install the bathroom pieces, all your rivet holes won't line up....
Kelly
kmb66 is offline   Reply With Quote
Old 06-06-2009, 08:39 AM   #27
1977 31' Sovereign
Manchester , New Hampshire
Images: 33
my first post! surly not my last, I have a million questions. We are the proud new owners of a 1969 Overlander. I think she has a bit of rear end sag, and certainly the bathroom needs a makeover. I think I need to remove the fixtures and I would like to know where to start.
Thanks for your help
Hey also look on youtube for airstream restoration and look for DYI I believe they did a overlander to. they have all the restoration.
1976 Airstream Sovereign International Landyacht (renovating)(found DOM plate said 1976)
1968 Airstream Caravel 17 footer
2004 Nissan Titan with BT package
K/N Cool intake air
Duel power exhaust
Mrcrowley is offline   Reply With Quote
Old 06-06-2009, 11:25 PM   #28
PizzaChop's Avatar
1973 31' Sovereign
Images: 202
I took it all out. I had to remove the curb side wall (actually double wall) to remove the screws which held the tub in place. I took the streetside out because the floor extended to just underneath the wall and I replaced the entire rear section.
Ron Kaes
Psalm 112
www.paparonnis.com
Has anyone ever converted a regular rear bath to a wet bath? tvadman1963 Sinks, Showers & Toilets 2 12-29-2006 11:15 AM
Shower pan removal in a 79 (rear bath) wdm Sinks, Showers & Toilets 0 06-11-2006 05:44 PM
Two piece bath removal C Johnson 1965 Caravel 10 04-16-2005 06:57 AM
Bath room light lens Igor68 Electrical - Systems, Generators, Batteries & Solar 1 08-31-2004 10:01 AM
Bath removal for just a '67 tradewind minkus 1959-69 Tradewind 4 07-09-2004 09:35 PM
