Old 05-10-2013, 11:16 AM   #1
Danruehl's Avatar
Brighton , Michigan
Bargman L77 core replacement
Hi all,
I ordered a new lock core for my L 77 but it doesn't want to lock in place. The old one came out fine and the brass pin lines up but the key won't rotate to make it lock in. Should I be installing with the handle locked or unlocked? Any other tricks? I believe the rotating pin is getting blocked and that's what is holding it up. Any help is appreciated.
thanks
Dan
Danruehl is offline   Reply With Quote
Old 05-10-2013, 11:46 AM   #2
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Originally Posted by Danruehl View Post
Hi all,
thanks
Dan
Hey Dan
Any luck figuring it out? I have a L77 and I'm waiting for a lock core to come in from Vintage Trailer Supply. Have you tried contacting them for help?
desertair27 is offline   Reply With Quote
Old 05-10-2013, 11:49 AM   #3
Danruehl's Avatar
Brighton , Michigan
Left a message yesterday. No reply yet.
Old 05-15-2013, 10:52 AM   #4
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Any update? I've got my old cylinder out and ready to install new one. I'd sure like to hear what you've done.
Mike
Old 05-15-2013, 03:00 PM   #5
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
I went ahead and installed my cylinder,it took me a while to realize the key is removed in the horizontal position and not vertical like all other locks.
I was lucky my old cylinder came out using the new key.
Hope you figure yours out.
Mike
Old 05-15-2013, 04:25 PM   #6
Danruehl's Avatar
Brighton , Michigan
Well, the second one failed as well. I really don't have much faith in this core replacement from VTS. I bought a nos on ebay for the same money and am going to take it to a locksmith to install. There is something binding the cam as I try to turn the key so perhaps its operator error.
Old 05-15-2013, 05:23 PM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If the key won't rotate. You don't have the brass pin lined up with the hole in the handle.
Replacing the cylinder is only the LAST step in getting this mechanism to operate somewhat freely.
The entire mechanism should be removed from the door. Then cleaned and inspected. It should be lubricated and reassembled outside of the door. And checked for correct operation. Prior to putting it back in the door.
DO NOT remove the bolt assembly from the lock while in the door. You will lose the detent balls and springs. This unit should be disassembled on a clean work bench, where you can keep track of the small parts.
Old 05-15-2013, 08:10 PM   #8
Danruehl's Avatar
Brighton , Michigan
Done. And it is lined up.
Old 11-14-2013, 08:00 PM   #9
1964 19' Globetrotter
Plainview , Texas
I'm looking for a bargman L-77. Not having any luck. Anyone have one to sell?
Texas star is offline   Reply With Quote
Old 11-14-2013, 08:17 PM   #10
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Do you have any parts of the L-77? I noticed you have 1964 trailer and if that's what this lock is for I think it should take the L100. I do see the L100 on ebay right now and from time to time the L-77 pops up there as well.
Mike
Old 11-14-2013, 08:17 PM   #11
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
There was one in the classifieds here just a week or so ago. Don't know if is still there.
Old 11-14-2013, 08:19 PM   #12
Plainview , Texas
I just bought a 1961 tradewind. It's going to be a real challenge. Starting with the handle?!?
Old 11-14-2013, 08:21 PM   #13
Plainview , Texas
The inside of the door is ok. Outside handle is broke.
Old 11-14-2013, 08:25 PM   #14
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Twinkie May have the outer handle you need.
