Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 07-23-2014, 01:16 PM   #1
2016 19' Flying Cloud
Deerfield Beach , Florida
Bargman L100 L200 Lock Cylinder
Has anyone had much success replacing the lock cylinder on a Bargman L100 or L200 Door Lock? Is there some secret as to how the old cylinder is removed? Thanks, Dom
dominicjohn is offline   Reply With Quote
Old 07-23-2014, 01:52 PM   #2
1997 25' Safari
1973 25' Tradewind
Greenville , South Carolina
I have a question? Is your lock cylinder damaged? Do you not have keys?
The easiest thing is to have a locksmith make a key for you.
If you want to remove the handle and key cylinder, first remove lock from door. Then remove four screws holding down cover plate over stem or latch. Remove all of the other parts covering the handle hold down screw. (note - if you have an older version, it will have a welded button holding the handle in place) Next, remove the pivot stem or strike pin which move by turning the handle. Once this pin is remove the cylinder I believe can be pressed out.
Contact me at r_whiten@hotmail.com and I think I have some pictures that might help.
All of this is difficult to put into instructions, but maybe you get the idea.
Rick
montanablue is offline   Reply With Quote
Old 07-30-2014, 05:15 PM   #3
Problem resolved, took the door knob assembly to a locksmith and $35 later fitted with three working keys. One item off the list, Soon to be out camping !!!!!!!!!!!!!!!
Old 07-30-2014, 05:26 PM   #4
1997 25' Safari
1973 25' Tradewind
Great! Happy Camper
Replace Bargman L 100/L200 with Fiamma, or other? Caddyshack Windows, Doors, Locks & Vents 1 04-06-2014 08:16 AM
L100 & L200 Issues... Frank's Trailer Works Exterior Storage Compartments & Access Doors 2 10-13-2013 10:31 AM
Bargman L100 lock 63 Safari airstream4 Doors & Locks 2 09-03-2010 05:18 PM
