Old 07-30-2015, 04:55 PM   #1
2016 30' Classic
Erie , Colorado
Baraldi Vent Hood power switch
So last night I went to turn off the fan on the Baraldi Vent Hood and the slider fell back into the switch assembly. Heard that this is a popular failure but couldn't find the post here on the forums.
I've got a replacement coming from Colonial, warranty but if you want an extra they are $100 or so.
In the meantime is there any way to do a temporary repair on the switch, even if it means dropping the hood? Maybe install an alternative, more robust set of switches?
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 07-30-2015, 05:18 PM   #2
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
We had the same problem and Airstream fixed it under warranty.
I can't believe that the switch alone costs $100!!! Wait until you see it! What a rip off!
If this happened to me while not under warranty, I'd probably rig a different switch under the hood and cover the hole with a piece of plastic or metal as the OEM switch is prone to fail and will do so again, I guarantee it.
Bob Martel
WBCCI# 5766
Old 07-30-2015, 05:35 PM   #3
2016 30' Classic
Erie , Colorado
Bob, so what was the repair? I see a total replacement unit at AirStreamSupply. Basically the dual switch unit and cables. Someone wrote a review and sounds like a straight forward pull and replace. Colonial said there was a clip that needed to be replaced. So not sure what to expect.
BARALDI SWITCH ASSEMBLY
Name:	Screen Shot 2015-07-30 at 5.38.21 PM.png
Gary
2015 Classic
ProPride
NVPN
Old 07-31-2015, 05:37 AM   #4
Chelsea , Michigan
Images: 12
Mine was under warranty and I was at the factory so I didn't see the actual repair and can't help you with the process. Go to the manufacturer's web site and see if there is a Youtube video.
Bob Martel
WBCCI# 5766
Old 07-31-2015, 07:53 AM   #5
2016 30' Classic
Erie , Colorado
Baraldi doesn't seem to have a website. Airstream does not have a manual, at least that they can share. Exchanged emails with Airstream Supply and they don't have a manual either. Anyone know a web address for Baraldi? Only one I found on the forum was for the US distributor from 2009 (aerycorp.com) and it is dead and company no longer appears to be in business.
Gary
2015 Classic
ProPride
NVPN
Old 07-31-2015, 08:11 AM   #6
2016 30' Classic
Erie , Colorado
A bit of an update. The Baraldi does have a website at Cappe Baraldi | Official Site. The Aery Corp is now the BCI Group and their phone number is (574) 975-0730. BCI was going to check on a manual and I have put in a request for the same from Baraldi. If I get something I will post it here.
Gary
2015 Classic
ProPride
NVPN
Old 07-31-2015, 08:45 AM   #7
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Mine broke too, and I'm well out of warranty. From the discussion, paying $105 just ticks me off. So I'm living with a broken switch.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 07-31-2015, 09:03 AM   #8
2016 30' Classic
Erie , Colorado
Ok an update. The company is VCI Group.
I took a few minutes and went out to the trailer to look at the setup. I dropped the air filter and could see the back side of the switch unit. From the back using a mirror I didn't see that the front plate or switch assembly was screwed in to anything.
The fan side of the front panel was loose so I lifted it and found that it was a simple plastic stud prong inserted into the switch assembly. I gently pulled the other side out and now the front panel with the sliders was loose and the switch assembly was sitting inside the hood.
The fan slider had popped out of the tracks that hold it in place. Likely by inadvertently pushing on the slider it popped loose and then pushed the switch assembly back releasing the stud prong on that side.
Snapped the slider back in. Got a long flat blade screw driver and went through the filter opening so that I could push on the back of the switch assembly while I snapped the front place back in on both sides. Aligned the switch openings to the switches and pressed back into place.
Photos below show the front panel piece, studs and sliders. Other photo shows the switch assembly in the hood. The square orange bits are the actual on/off switches. The front panel sliders simply fit over the switches.
So and easy fix. 5-10 minutes. Repair is easy if the prongs have not been damaged.
Gary
2015 Classic
ProPride
NVPN
Old 07-31-2015, 11:50 AM   #9
2015 25' FB Flying Cloud
Sandy , Utah
Thanks for the info. Mine broke on my 2 month old 25FB. On mine one of the posts actually had broken off. AS is sending me a new one. I think mine broke because it was so hard to slide the switches back and forth. I plan on greasing the track on the new one before I install it. What type of grease do you think would be best? Dielectric or silicone based?
rocco52 is offline   Reply With Quote
Old 07-31-2015, 01:04 PM   #10
2016 30' Classic
Erie , Colorado
I don't think grease would help. The tracks are not all that robust and there is no binding. The slider could be improved if the part you 'grab' just stuck out a bit further. Sounds like it somewhat common that folks reach to slide it, unable to get a good 'grip', push in as they try to get it to move and poof, they have pushed in and pushed the slider into the switch and dislodged the switch assembly.
I can see how a post might break off. I was lucky. Overall an elegant "Italian" design but not very practical in daily use .
Gary
2015 Classic
ProPride
NVPN
Old 07-31-2015, 01:53 PM   #11
Chelsea , Michigan
Images: 12
Thanks for the follow up Gary!
Bob Martel
WBCCI# 5766
Old 10-16-2017, 07:42 PM   #12
Pacific Grove , California
I think this switch assembly is made of cheap brittle plastic. I have a 2015 AS, bought used that was unused. 3rd person to push the range hood switch broke it. I mean it should withstand normal pressure. It pushed the switches back into the housing. the plastic cover trim has 2 tabs. One broke off. It is quite aggravating. I've clicked on the links above. Cannot find the part number or place to buy it. But then again, I'm thinking of a couple SS toggle switches. Has anybody found a work around to this?
VRSCDX is offline   Reply With Quote
Old 10-16-2017, 09:53 PM   #13
2016 30' Classic
Lorton , Virginia
$100 switch for an entire hood that cost less than $15 to make, ahahah
Zybane is offline   Reply With Quote
Baraldi Range hoods, The Stainless steel Range hood found in 2009 Airstreams AeryCorp Commercial Listings 18 05-10-2016 01:41 PM
Slightly used Baraldi Range Hood Snaken49 Airstream Classifieds 0 01-26-2015 02:37 PM
Baraldi Vent Easy to Install? KJRitchie Stoves, Ovens & Microwaves 13 11-07-2014 01:20 PM
LED Conversion: Baraldi Range Hood Lights TinTin Lights - Interior & Exterior 5 07-13-2014 02:38 PM
Hood/hood lights and water heater stopped working!!! Thomas_G Electrical - Systems, Generators, Batteries & Solar 1 06-17-2013 12:49 PM
