Originally Posted by Brian Hobin
Hello, would you be able to direct me to a probable earlier question in the forum on how to install the drivers side banana wrap? For the second time a truck tire tread smashed ours. I have the hole covered by two aluminum stove pipe pieces and aluminum tape.
I have been given a website on where to order a vinyl banana wrap replacement but I do not know how to install it once received.
I hope that someone has addressed this earlier in the Forum so that I can read it and gain some confidence in attempting a solution. Are any special tools needed?
Regards
Brian Hobin
I don't no how your AS is configured on side, as far as vinyl insert, all AS have rub rail along lower side. I can tell you to remove on 76 AS. Rub rail along side at bottom has blue vinyl insert, it will come out very easily, just pinch and pull out, next rubrail is pop riveted on drill those out, remove enough to expose wrap, you can leave hang but tape up end so doesn't sag, next wrap is pop riveted at top and underneath, drill out reinstall reverse. Caulk along top of wrap, then after installing rub rail caulk along top edge, insert vinyl strip. Very easy job little skill involved. Tools you will need pop rivets caulk and riveter. Rivets avbl. big box stores var. diameters. I use Marson klik fast riveter, will last lifetime. If you have any Q. pm me with ph# I can walk you thru process.
Bill
