Old 11-17-2019, 10:48 AM   #1
Scotts Valley , California
ball coupler recall
We are getting ready to purchase a 2019 or maybe a 2020 Globetrotter. We just heard about the recall. We are wondering if we should wait until the problem is fixed at the factory or go ahead and get one with the modification that will ensure the proper clamping force.
heymana is offline   Reply With Quote
Old 11-17-2019, 11:59 AM   #2
Mollysdad's Avatar
Read this thread:
http://www.airforums.com/forums/f464...ml#post2307795
Demco was professional to weigh in on the issue and procedure.
Old 11-17-2019, 02:47 PM   #3
KK4YZ's Avatar
2020 28' Flying Cloud
2017 23' Flying Cloud
Hiawassee , Georgia
I believe the dealers have the kit to test the couplers. Insist that yours be tested prior to purchase.
KK4YZ is offline   Reply With Quote
Old 11-17-2019, 03:54 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If I were to have the coupler replaced. I would insist on a Bulldog coupler.
Old 11-17-2019, 06:43 PM   #5
Julie-Bob's Avatar
2009 25' FB Classic
Scottsdale , Arizona
Airstream will notify owners, and will send a temporary use adaptor that can be slipped over the ball portion of the coupler to allow owners to tow their trailers. For the final remedy, dealers will add a shim plate to the backside of the ball coupler clamp to put it in position to apply the required clamping force on the tow ball, free of charge. The recall, #19V753000, is expected to begin December 20, 2019. Owners may contact Airstream customer service at 1-877-596-6505 or 1-937-596-6111 extension 7401 or 7411.
Bob & Julie # 5587, 4CU in AZ
Julie-Bob is offline   Reply With Quote
Old 11-20-2019, 09:44 AM   #6
2020 25' Flying Cloud
Alexandria , Minnesota
Originally Posted by julie-bob View Post
airstream will notify owners, and will send a temporary use adaptor that can be slipped over the ball portion of the coupler to allow owners to tow their trailers. For the final remedy, dealers will add a shim plate to the backside of the ball coupler clamp to put it in position to apply the required clamping force on the tow ball, free of charge. The recall, #19v753000, is expected to begin december 20, 2019. Owners may contact airstream customer service at 1-877-596-6505 or 1-937-596-6111 extension 7401 or 7411.
This coupler is welded soundly to the A frame , so there is no easy replacement/ alternative brand. AS is providing a shim? That sounds a bit flimsy?
cicho69 is offline   Reply With Quote
Old 11-20-2019, 02:49 PM   #7
mikeinca's Avatar
2020 25' Globetrotter
Santa Rosa , California
Originally Posted by cicho69 View Post
Attachment 356566
Read through the thread referenced in post #2 above. The problem and solution are thoroughly discussed there but the bottom line is that, given what the actual concern is, shimming is a perfectly reasonable solution.
The thing about science is that it's true whether or not you believe in it.
― Neil deGrasse Tyson
2018 30' Classic Twin (sold)
2020 25' Globetrotter Twin (here!)
2017 F250 4x4 6.7 max tow Platinum
mikeinca is offline   Reply With Quote
Old 11-20-2019, 03:28 PM   #8
eagletoo's Avatar
2020 23' Globetrotter
Long Island , New York
Well said, Mike
Bruce
2020 23 Globetrotter FBT Natural Elm/London Grey
2018 Jeep Overland 5.7L Hemi
Id rather be camping is an understatement!
eagletoo is offline   Reply With Quote
Old 11-20-2019, 10:04 PM   #9
Boyden , Iowa
Attachment 356566
Cicho - if you have concerns about the shim please let me know i can run you through all the details !
Demco is offline   Reply With Quote
Old 11-21-2019, 07:21 AM   #10
My point is shims are utilized in assembly for variances. A coupler is a 5-6 piece assembly. Why wouldn't the tolerances been tightened in the original design? The coupler should have been thoroughly tested by the mfgr prior to its release!!!
I know AS did not design this coupler, it came on their new chassis. Did that chassis mfgr use this as a better design or a cost savings?
Old 11-21-2019, 03:22 PM   #11
Boyden , Iowa
Cicho - The design of the coupler is not to blame, every part within the coupler has tolerances plus and minus that are accounted for. It was a welding fixture problem that let a part be welded in the wrong spot.
Old 11-22-2019, 08:27 AM   #12
So it's the positioning of 'internally welded backing plate' that the under jaw slides against, right?
If so, what thickness shim will be utilized? Is it to be welded on the face of the backing plate? or the back of the jaw?
I do see a bit of wear in the back of ball section of the body on my unit with only about 2000 miles.
Best way to remove coupler from ball JBinKC Hitches, Couplers & Balls 3 02-16-2010 05:59 PM
Alignment of ball an coupler Harper Hitches, Couplers & Balls 6 06-10-2008 06:06 PM
Replace ball coupler on 22ft Safari Killo1 General Repair Forum 1 04-24-2008 03:27 PM
couldn't get coupler off the ball qqq Hitches, Couplers & Balls 20 10-02-2003 02:00 PM
