Old 10-23-2017, 10:21 PM   #1
Okanagan , BC
Bad Tree Scrape picture... can this be fixed easily?
we are looking at purchasing this unit... worst part is the tree scrape at the back... is this an easy / quick fix? can the molding be replaced or not... what are our options? there is also darkened areas above the scrape under the window frame and rivets ... is this normal?
Name:	Scrape on body moulding.jpg
jjAIR is offline   Reply With Quote
Old 10-23-2017, 10:40 PM   #2
1991 25' Excella
Santa Ynez , California
Quick easy fix on damaged aluminum? Lots of us would love for that to be true! Reality is your dealing with a material that does not magically return to pre damaged condition without adding sufficient effort or $. The simpllst repair can be expensive to return to new condition. If you need perfect then look hard or buy new. Otherwise accept blemishes and the value reduction they present.
AlinCal is offline   Reply With Quote
Old 10-23-2017, 11:47 PM   #3
Okanagan , BC
Thanks AlinCal; i like your reply alot better than the one previous to yours... well said.
Old 10-24-2017, 01:12 AM   #4
1980 24' Caravelle
vallejo , California
welcome jjair: being a vintage as owner, these blims a part and parcle of as ownership. if the price is right and the rest of the trailer is to your taste, than go for it. good luck. kurt
ke6gkv is offline   Reply With Quote
Old 10-24-2017, 06:52 AM   #5
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Western WA , Washington
My primary concern would revolve around whether a leak is associated with that scrape. If not, I would not worry much about it. If so, you will either want to dig deep into whether there is water damage or just move on to another trailer.
Rocinante is our 2014 International Signature 27FB
Old 10-24-2017, 06:59 AM   #6
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
All I see is a scrape on the trim. That is easily replaced- it sticks on with double sided tape.
I just noticed the photo is titled "scrape on body moulding". Bingo. Easy fix.
2012 Dodge Durango Hemi/AWD
Old 10-24-2017, 07:22 AM   #7
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
The scrape on the trim piece is immaterial and will not affect the trailer other than aesthetically. Also, these are normal and you will eventually add your own dings. I actually have basically the same thing on my trailer.
The dark area under the window is harder to see in this image but it might just be some of the sealing material (i.e., caulk) that is bleeding out of the seam around the window frame (worth another look to confirm.) If that's what it is, then this too is perfectly normal and of no concern.
Bob Martel
WBCCI# 5766
Old 10-24-2017, 10:11 AM   #8
VaTravelers's Avatar
2017 28' International
Virginia Beach , Virginia
I purchased a new trailer and not looking forward to my first boo boo, so buying a trailer with known blemishes relieves you of that worry. The only concern (mentioned above) I would have is when the trailer hit the tree was there sufficient force to bend or damage the window frame, which could cause a leak. Welcome to the forum and good luck with your decision. We have owned our AS for 1 year and have nothing but great things to report! Safe travels.
VaTravelers is offline   Reply With Quote
Old 10-24-2017, 10:28 AM   #9
2006 30' Classic
1966 20' Globetrotter
Dover , Delaware
The aluminum trim piece comes in a 20 foot length and is riveted on with blind rivets, if you look closely you will see where it starts and stops. The center is sold in a 100 foot roll and is peel and stick. It is not a difficult job to replace both if you have some experience with pop rivets. Hope this helps, I don't like damage on my trailer either.
helwigc is offline   Reply With Quote
Old 10-24-2017, 06:16 PM   #10
1994 35' Land Yacht Diesel
Denton , Texas
The Last Lecture
If you haven't read this book by Randy Pausch, there are two incidents that he refers to that apply to this post. -The first, when his wife damaged his car, the second when he introduced his niece and nephew to his new car. Highly recommend this read!
dajen54 is offline   Reply With Quote
Old 10-24-2017, 08:15 PM   #11
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Friend, that isn't even the beginning of an oops!
Old 10-24-2017, 09:13 PM   #12
John Geisen's Avatar
2005 28' International CCD
Palm Beach Gardens , Florida
It doesn’t appear to have damage beyond the scrap. It there are no leaks I wouldn’t give it another thought. -John
John Geisen is offline   Reply With Quote
Old 10-24-2017, 10:49 PM   #13
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
Looks like simple beltline trim repair. However, the riveted aluminum rim that hold the rear window in appears to have the dreaded filiform corrosion. Look that up online and see how to effectively deal with it. I would imagine if it is there you will see it on other aluminum parts. It is actually easy to prevent once what you have is brought under control. Alway regularly wax all rivet heads and sheet metal edges as they are the most vulnerable. They are not clear coated during manufacture.
guskmg
Brake Controllers - can they be added easily? britta315 Towing, Tow Vehicles & Hitches 14 09-09-2017 10:16 AM
Repairs after a tree scrape clamb General Repair Forum 13 09-22-2015 02:28 AM
Deep scrape repair help Rmoran113 Ribs, Skins & Rivets 5 01-27-2012 11:50 AM
removing scrape batt Ribs, Skins & Rivets 5 09-30-2010 10:13 AM
Scrape crunch rip, ouch, parking accident, repair suggestions? jacarape General Repair Forum 12 12-16-2008 10:04 AM
