Old 06-12-2015, 03:37 PM   #1
1974 27' Overlander
Fresno , California
Question Axles replacement '75 Overlander
I am doing a shell off restoration and want to replace the entire axle assemblies.
Question?: Going to use Drexel Axles and need some advice, as the restoration will most likely add a little weight, should I use 4000lbs axles and they offer a 10 or 22.5 degree down angle. Any advice or insight would be appreciated.
AlumCasa74 is offline   Reply With Quote
Axles Axles Axles GeocamperAS Axles 33 11-20-2015 12:01 PM
Replacement axles on a '73 Tradewind BossCamper Axles 3 09-24-2009 08:07 AM
Axles for '70 overlander FrenchBern Axles 44 06-02-2007 06:11 PM
New axles for my '73 Overlander 310astream Axles 1 04-21-2007 06:08 PM
