Old 08-30-2013, 06:51 AM   #1
Macdady's Avatar
1968 22' Safari
Concord , North Carolina
Axle Inspection - '68 Safari single
I recently picked up a 68 Safari 22' with single axle, what specifically do I need to look for/at on the axle, or should I just assume its 45 years old and needs replaced like everything else mechanical in the trailer? I know for a fact the trailer was towed very minimally over its life time.
Macdady is offline   Reply With Quote
Old 08-30-2013, 08:14 AM   #2
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Welcome Aboard....
That would be a rational assumption on an original axle. Especially on a unit that has been sitting and not used a lot.
Jack it up, (on the axle mount plate), if the tire is hard to remove and there is little or no axle arm deflection it's time to go.
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 08-30-2013, 09:12 AM   #3
Torsion axles do not last 45 years, especially when not used very much.
It's not the axle that goes bad, but it is the rubber rods within it.
Rubber must be exercised to stay alive.
The following article will help you check it out.
The Dura-Torque Axle
Old 08-30-2013, 09:26 AM   #4
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Count needing an axle. You can look at the angle of the torsion arm and if it is horizontal then there is no "flex" left in the rubber rods that make the torsion suspension work. When you jack it up, if the tire moves up just as the trailer body starts to lift then there is no suspension left. Considering the age of your trailer I would get a new axle. Remember you will get new brakes installed on the axle so it is really the way. I got the axles for my 68 from Colin Hyde and would certainly get them from hime again if I ever redo another Airstream.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 08-30-2013, 09:30 AM   #5
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Check out Inlandrv.com. They have a really good article on testing an axle.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 09-03-2013, 10:53 AM   #6
Macdady's Avatar
1968 22' Safari
Thank You all for your response!..
1971 Safari Axle Replacement pickerdd Axles 42 09-23-2015 05:47 PM
Video - Successful Axle Job on 1964 Safari JitneyBead Axles 10 05-21-2012 09:07 AM
14" to 15" on single axle???? tinbender Wheels, Hubs & Bearings 3 01-16-2012 07:49 AM
1973 Vintage Airstream Safari 23 foot rare dual axle eBay Watch Airstreams on eBay 0 06-13-2011 01:50 AM
Streamline 21' Single axle Jim & Mitzi Vintage Kin 9 04-26-2011 05:04 PM
