Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 04-01-2013, 09:40 AM   #1
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
awning rail leak and removal..
I have a leak in the awning rail attachment on the curb side. I do not see any effective way to add caulking to fix it. Airstream caulked it 4 years ago. I am thinking about taking the awning and awning rail off and re caulking and re-attaching. Has anyone done this. Can it be rivited back from the outside using olympic rivets or something? Was it attached from the outside to start with? What is best way to remove old rivets, drill them or try to grind off the heads?
I need to do a temporary fix because the traile is going to sit in the open for 6 months. Thinking about taking the awning and rail off now and caulking the holes and then doing the actual repair next fall.
Any suggestions are welcome.
Old 04-01-2013, 10:32 AM   #2
Zeppelinium's Avatar
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake , Colorado
you have to drill out the rivets. Alternatively, you can use a sharpened putty knife and hammer to cut them, but this is usually only resorted to when you have a hidden rivet that you can't drill out.
If you can find the loose rivet(s), replace it with an Olympic. This probably won't pull the rail down tight enough to stop the leak, so apply some Trempro/Vulkem under the rail before you replace the rivet (You can get a little bit of a gap with a thin tool). You can remove the old caulk more easily if you heat it with a heat gun.
IMHO, I wouldn't remove the rail. It wouldn't be a big project if you're just going to Olympic it back on with some Trempro underneath, but I'm leery of the Olympics for holding the rail under the flapping and jerking the awning can exert in a wind (they won't fail, but I think it would be easy for them to loosen enough to start a leak again). I'd just caulk the top side of the rail along its full length (I assume you tried this). It won't be visible--use the rounded edge of something like a motel key to get a nice bead along the edge.
Zep
Zep@Charmedquark.net
Old 04-01-2013, 12:00 PM   #3
1988 25' Excella
1987 32' Excella
Thanks. I went ahead and removed the rail. It looks like Airstream did the same thing 4 years ago when I had it in. Fresh caulking under 3/4 of it, old caulking under the rest. I am going to clean off the old vulkem, vulkem the rivet holes, and leak test the wall again. Right now I need a dry trailer worse than I need the awning.
Old 04-01-2013, 06:11 PM   #4
1973 23' Safari
1977 23' Safari
not a bad decision, just a bit more work. Let us know how it turns out.
Z
Old 04-02-2013, 10:44 AM   #5
1988 25' Excella
1987 32' Excella
Thanks for your suggestions. We were leaving the trailer on site in Fl for the summer. I caulked the vista windows and am storing the awning until we return next fall or winter. 36 rivt holes. I am thinking about remounting the awning attachment rail on standoffs so that water can drain. Any comments on that? The current rivet holes are now oversized and irregular. It looks like airstream actually took the support partially off and re-riveted it when they worked on it.n
Old 04-03-2013, 03:50 AM   #6
1973 23' Safari
1977 23' Safari
Originally Posted by Bill M. View Post
... I am thinking about remounting the awning attachment rail on standoffs so that water can drain. Any comments on that? ...
That might work if you used a rivet washer and solid rivets. But I think it's risky. Even a small standoff distance will give the rail some leverage on the shell skin and I think just a few flaps in a wind and you'll bend either the rail or the skin. Even if nothing bends, that small amount of leverage could work the rivets loose.
AEROWOOD is one of the members who would know the answer.
Zep
Old 04-07-2013, 04:46 PM   #7
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Since you mention that the current rivet holes are oversized and irregular, re-rivetting the awning rail using the same holes would not produce any good results. FWIW, you may want to consider having a single strip of aluminum to patch over the previous mounting points and then reattaching the awning rail over the top of that. At least you will know that it will have strength and integrity. I would also mention that if you do decide to do this, use olympic rivets that do not have neoprene washers, and dab some Vulkem around the base of the rivet before putting it in.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
Old 04-08-2013, 04:29 PM   #8
1973 23' Safari
1977 23' Safari
Originally Posted by blkmagikca View Post
...if you do decide to do this, use olympic rivets that do not have neoprene washers, and dab some Vulkem around the base of the rivet before putting it in.
em-fa-sis added.
Old 04-08-2013, 05:25 PM   #9
Central , Mississippi
Keep in mind if you stand off the rail, rain water will POUR down the side while you are standing under your awning attempting to stay dry in the light rain shower.
IMHO, it's not too hard to install a rail and keep it from leaking.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 04-17-2013, 11:50 AM   #10
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Bill,
I'm a little late to this party, but you might want to look into a roll of EternaBond's product called "Alumabond". I think it would solve your problem. I just bought two rolls of it, and am sealing every thing on the roof of our 2001 Excella 30' AS.
I got the 3" wind roll. This stuff is incredible! It's easy to apply, and lasts for years....
Good luck!
Larry
Larry C is offline   Reply With Quote
Old 04-21-2013, 09:15 AM   #11
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Larry C -- I had used Eternabond tape on the roof of my Land Yacht motorhome, as the body was fiberglass. However, this was to seal the seam. In Bill M's case, the issue is that the rivet holes have been enlarged, as he put it "The current rivet holes are now oversized and irregular." This means that he will have difficulty re-attaching the railing, as rivets have to be snug in properly sized holes - too large is not good. Thus, a patch would be the best permanent solution, and one that is done regularly with AS trailers. I believe that the holes drilled for the Olympic rivets should be with a No. 21 drill (please correct me if I'm wrong, as I would have to rummage through my truck for the rivet kit I carry). Any size larger will not provide the integrity and strength that you need. As well, remember to make sure that the neoprene washers on the rivets are REMOVED BEFORE you use them.
VE3JDZ
AIR 12148
WBCCI 8080
Old 04-21-2013, 10:35 AM   #12
1973 23' Safari
1977 23' Safari
...rivets have to be snug in properly sized holes - too large is not good. Thus, a patch would be the best permanent solution, and one that is done regularly with AS trailers. I believe that the holes drilled for the Olympic rivets should be with a No. 21 drill ...
yes, 21 is correct.
#40 for 3/32 -- sometimes in window frames
#30 for 1/8 -- original shell rivets, outside solid, inside pop
#21 for 5/32 -- Olympics, or when using universal head rivets to get a similar head size to the original brazier head solid rivets
#11 for 3/16 -- belly pan
Zep
Old 04-22-2013, 07:25 AM   #13
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Good point about the enlarged holes! Another way of dealing with that would be to go to the next size larger rivets....
Larry
Old 04-23-2013, 09:05 PM   #14
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Larry, unfortunately, there is no next size larger rivets - he has to stick with Olympic rivets as they are waterproof and look just like the bucked ones. Thus the patch is the only good long term solution.
VE3JDZ
AIR 12148
WBCCI 8080
Old 04-24-2013, 03:49 AM   #15
1973 23' Safari
1977 23' Safari
Unless I missed some detail about this rail installation, I believe it was originally installed using 1/8" solid brazier rivets. If those holes are now oversized, drilling them out to 5/32" and using Olympics should work without a patch. Z
Old 04-24-2013, 07:49 AM   #16
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
I realize that the Olympic "shave rivet" has been the standard to replace the bucked rivet for a long time. However, you might want to check out this link.
Olympic does make shave rivets in several different diameters. Usually, the rivets on the awning rail are not visible from the ground, so if the head diameter were a few thousandths of an inch larger, it wouldn't make any difference, and it should be stronger.
To me at least, it would warrant looking into...for whatever it's worth.
Byler Rivet - Shaveable Head Bulb-tite Rivets (RV6607)
http://www.bylerrivet.com/products/p...tegory117a.pdf
Larry
Old 04-24-2013, 07:58 AM   #17
1981 31' Excella II
New Market , Alabama
By main awning was attached with buck rivets at the factory. However, the other three awnings were installed with simple pop rivets. If it is a main awning, by all means use Olympic rivets. My street side awning rail was ripped off the trailer in a tornado. This one was pop riveted on. I think I used 3/16 pop rivets on it with Trempro-635 underneath it. The adhesive will probably do more to keep it on than the pop rivets. I do remember drilling the old rivets out was a pain because the skin would deflect. I think I also had to use a ballpeen hammer to get the skin flat again where the rivets were ripped out. I would not use pop rivets on the main awning. It will fail in short order. My small awning seems to be doing ok with pop rivets.
Originally the rails were sealed with that CRAPPY GUM TAPE. This stuff will seal for a month or two then skrink. It also provides no adhesive value to help hold it on there. The Trempro will provide alot of adhesion over the area we are talking about. I still would not trust it to hold a main awning rail on.
If the rivets are loose and the rail will move then you need to fix it right. Otherwise caulk will fix it.
Perry
Old 04-24-2013, 08:06 AM   #18
1988 25' Excella
1987 32' Excella
Thanks very much for the suggestions. I will not address this issue until Nov or Jan. I do plan on some type of patch and re-installation. The rivets I drilled out were pop rivets. 30 something of them. One small crack in the Al under the support. The awning is a curbside awning. I do plan to space a drain somehow because the water backs up over the glaze of the vista window. I am thinking about a patch of a 1/8 or1/4 inch by 1 1/4 Al strip epoxied (jb weld maybe) and riveted. Then re-attach the awning rail with Olympics in new holes through the patch and trailer skin. The awning is on the sunny side and we use it. Since I have to do the patch anyway I will probably put it back on.
Old 04-24-2013, 08:10 AM   #19
1981 31' Excella II
The Olympics will work even if the holes are distorted. I would use something flexible instead of JB-weld if you go the patch option. The JB-weld will crack when the trailer flexes. My main awning sags in the middle and water pools there. If you can make the center slightly higher you will be better off.
Perry
