Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 08-18-2014, 09:17 AM   #1
1991 29' Excella
Rockwood , Ontario
Awning Problem - 91 Excella 29ft
Being a new owner as of last year, and after watching the ZipDee video about opening the big awning, I thought it would be no problem…wrong!
After I loosen the wheels and bring them around the upper rail, then I go to hook the strap and pull, I can't pull it down. Is there something else that might lock on the railing that was not on my model year in the video? Or is it because it has not been opened up in about a year (which was at the dealer, when we went through the operations together), or is it because I am a 135 lb. weakling?
Hope someone can help, because it is about time to get the awning down…
breezyway is offline   Reply With Quote
Old 08-18-2014, 09:29 AM   #2
BessieB's Avatar
1997 21' Excella
Carson City , Nevada
Images: 8
there's a lock on right
There is a lock on the right of the awning just to the left of the wheelie locks, if it is like mine. Black with a hole to put the tool into it. Just pull it down and it is now unlatched.
BessieB is offline   Reply With Quote
Old 08-18-2014, 09:47 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
The above mentioned lock is on the end of the awing barrel and in the locked position folded down so it lays even with the barrel. Most A&E have a hole in the top of this lock that you can hook with the awing stick and pull it up. Once unlocked you can open the awing.
When you open the awing you have to hold the awing open and go to the lock and relock before you set the arms. If not the awing will recoil itself.
When you roll the awing up remember to relock this lock as it is one of the safeties that keep the awing closed while traveling.
2004 Excursion 4x4
Old 08-18-2014, 10:31 AM   #4
BessieB's Avatar
1997 21' Excella
Images: 8
Cool!!!! I didn't know that one about locking once the awning is open. I just wrote ZipDee about the play in the right arm that has play in it. Don't know if that is normal or not.
Old 08-18-2014, 06:45 PM   #5
1991 29' Excella
Rockwood , Ontario
Awning Problem Solved
Thanks as always to my fellow 'Streamers'. I found the black tab like thing that is on the right side near top end of roller. No problems pulling awning down after that. I even found the instructions on how to set arms, etc.
It sure looks awesome with the awning down!
AIRSTREAM 1993-29ft-EXCELLA- PRICE REDUCED QUEEN-BED.- AWNING-NICE COND.FLORIDA eBay Watch Airstreams on eBay 0 04-20-2013 03:00 PM
AIRSTREAM 1993-29ft-EXCELLA- R- BEDROOM QUEEN.- AWNING-NICE COND.FLORIDA eBay Watch Airstreams on eBay 0 04-13-2013 01:10 PM
Finally found my 1989 29ft excella Streamer Dan Member Introductions 10 07-14-2011 09:04 AM
1991 Airstream Excella 1000 Limited 29ft Trailer USA eBay Watch Airstreams on eBay 0 03-16-2010 04:00 PM
How to replace floor in a 1991 29ft Excella? walden91 Repairing/Replacing Floor &/or Frame 2 01-26-2010 08:04 PM
