Old 04-13-2014, 03:18 PM   #1
Brooklyn , New York
Awning installation - 1975 Overlander 31 ft
I am wondering if an awning can be installed on any 1975 Overlander or if it had to be done as a factory install at time of purchase. If it can be done, what is a ball park cost?
Thank you.
guyinbrookly is offline   Reply With Quote
Old 04-13-2014, 03:24 PM   #2
Central , Mississippi
Sure one can be installed! Here is how I did mine...
http://www.airforums.com/forums/f109...ml#post1406024
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 04-13-2014, 03:34 PM   #3
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Zip Dee will cut them to length. You can definitely install an awning, but it's not the easiest task. This is a fairly comprehensive thread on variations in how to do it. Pay attention to post #10. I have had professional installers also say they think the rollers come a tad long. If you decide to go ahead, you might call Zip Dee and discuss this issue with them.
I would definitely reinforce the attachment locations if you can get at the inside of the shell.
Here is a link to the original instructions, which tells you about the spring in the roller.
Sometimes the roller or arms can get jammed by sand. Getting the awning operational can result in other problems. You can also repair a roller if the fabric separates from the tube slot.
Zep
Vent lift installation & Astrodome installation jessejane Roof Vents, Skylights & Fans 4 01-10-2014 04:34 PM
1975 Airstream Overlander :: 1975 Airstream Overlander 75OLANDER Airstream Registry Discussions 0 01-02-2014 02:14 AM
Rivet Question - Awning Installation 65CV Ribs, Skins & Rivets 4 09-27-2008 04:47 AM
New Awning Installation Don Tucker Awnings 2 07-30-2003 12:12 PM
Zip Dee Awning installation thenewkid64 Awnings 3 04-19-2003 10:08 AM
