Old 10-14-2015, 04:58 PM   #1
NOAZRK
NOAZRK2690's Avatar
2004 34' Classic S/O
Kutztown , Pennsylvania
Atwood Gas/Electric Water Heater Melted Wires
On the 2004 AS with a Gas/Elec. Atwood MPD93235 water heater, there's a junction box close to the electric element. Inside the junction box there's a relay that clips onto the back side of the cover plate. The relay is part number 93849. I had to replace that relay because of a factory assembly error. Atwood requires the installer to use 90 degree Centigrade wire. Mine was installed with 60 C wire. I have replaced the element and rebuilt the connections with 120 C wire and all the appropriate connectors however everything in the junction box was too melted/burned up to trace which wire goes to which tab on the relay and to the element. I assume the relay turns 110v to 12v which allows the electric element to be switched with a 12V toggle switch mounted on the bathroom wall. My assumption could be wrong. Could someone lead me to a photo of a correctly wired relay in the junction box or site specific instructions? Appreciate any help that's offered! In an effort to cut-to-the-chase, other wiring arrangements that don't specifically use the 93839 relay probably won't be much help.
NOAZRK2690 is offline   Reply With Quote
Old 10-14-2015, 07:08 PM   #2
richinny's Avatar
2011 34' Classic
http://www.airforums.com/forums/f445...ire-73813.html
just some info on your prooblem. i don't think the pictures will help but the atwood site might have a wiring diagram.
Ricky
URGENT HELP NEEDED - Found Melted Wires This Afternoon BoldAdventure Refrigerators 24 05-04-2015 11:28 PM
Atwood LP/Electric Water Heater Problems (Electric Has Failed) gquake Water Heaters, Filters & Pumps 10 06-29-2014 03:02 PM
Atwood Gas water heater - 'click then shuts off'???? kevinyyz Water Heaters, Filters & Pumps 3 05-11-2009 10:18 AM
Atwood water heater -- light on, no gas or spark ChromeNomad Water Heaters, Filters & Pumps 4 02-27-2009 09:51 AM
Switch for Atwood Gas/Electric Water Heater tr674 Water Heaters, Filters & Pumps 8 07-20-2008 10:33 PM
