Old 12-28-2016, 07:13 PM   #1
vincaroo's Avatar
1991 25' Excella
1995 34' Excella
Atlanta , Georgia
Atwood Furnace Replacement
Hey All,
Getting ready to replace our furnace with a new Atwood Excalibur iv in our new 1995 34' Excella 1000. I know that Suburban is far more common, but I'm replacing an old Atwood that was already there and the dimensions are right. Does anyone know of a post that anyone has done showing a step by step instruction with photos for demonstrating the replacement?
Jeff
vincaroo is offline   Reply With Quote
Old 12-28-2016, 09:04 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
No, but I just had a blower motor replaced on my 93. The Atwood looks like a fairly easy replacement. I will follow this thread with interest.
Old 12-28-2016, 09:33 PM   #3
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Years ago Atwood started removing the general/internet availability of information for their products; probably due to legal concerns about DIY work. They are quick to recommend you go to a shop rather than attempt self service if you call for help/insight. However, Atwood is pretty good at supplying parts if you know what you need so the part names in the link below might be of some assistance.
http://www.ntpdistribution.com/PDF/V...bur8500III.pdf
That noted, some material on earlier generations can still be found on the net that might help you figure out your install challenge. For example:
http://bryantrv.com/docs2/docs/hflamefurn04.pdf
As for pictures and a 'how-to' thread on the forums, I haven't seen one. There are some about the Suburban for whatever insight that provides.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 12-29-2016, 07:48 AM   #4
vincaroo's Avatar
1991 25' Excella
1995 34' Excella
Atlanta , Georgia
Thanks for the replies. I'll try to take some good pictures and post them when I tackle the job.
Old 12-29-2016, 05:21 PM   #5
2007 27' Classic FB
Ridgefield , Washington
Images: 11
Have you checked YouTube?
John
Woosch is offline   Reply With Quote
? best - Atwood or Suburban Furnace? prhamilt Furnaces, Heaters, Fireplaces & Air Conditioning 12 05-09-2015 11:33 PM
Atwood Everst Star Furnace problen. cooperhawk Furnaces, Heaters, Fireplaces & Air Conditioning 2 03-30-2008 05:17 PM
Bowen/Atwood LP to Atwood LP/ELEC./DSI? 65 overlander Electrical - Systems, Generators, Batteries & Solar 9 12-05-2005 07:10 PM
Atwood furnace issue--Help?! Silvertwinkie Furnaces, Heaters, Fireplaces & Air Conditioning 9 03-01-2005 09:31 AM
Atwood 7916-II furnace Silvertwinkie Furnaces, Heaters, Fireplaces & Air Conditioning 0 05-18-2003 12:05 AM
