Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 08-05-2016, 06:05 PM   #21
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Originally Posted by Papa smurf View Post
I do not know where you got that information about CSA but in Quebec you can find them everywhere
I live in Ontario, and shop in Ontario, and my information is told to me by Ontarioans.
MelGoddard is offline   Reply With Quote
Old 08-05-2016, 06:09 PM   #22
Originally Posted by banderabob View Post
I also need to get the heater vent screen from Amazon. But, here's what I did for the water heater and two fridge doors. I bought a small roll of metal screening from the local hardware store, cut to fit each door, and glued to the inside of each door with clear silicone.
That works!.
Clear silicone is also used in the CRJ jet to fasten temp sensor wire to the front wing spar.
I've used it to fasten large mesh window screen to my Maxx-Airrs and inside the Air conditioner housing to keep birds and bugs out.
Old 08-05-2016, 06:14 PM   #23
Originally Posted by franklyfrank View Post
The part that is south of Chicago.
I had wasps build a nest in the anchor well of my boat and the shed but never any problems with the AS.
Part of the year we are in FL and part in IL. in between bumming around out west.
Yer very lucky!
Old 08-05-2016, 07:41 PM   #24
2016 27' International
Montreal , Quebec
The C in CSA stands for Canada and last time I checked Quebec was still part of Canada. Unless you can come up with valid information from CSA I have to think that your assertion is hooey as you say so well.
And as for getting your information from Ontarioans you might want to multiply your sources and check your facts before presenting an urban legend as a fact.
Papa smurf is offline   Reply With Quote
Old 08-05-2016, 08:33 PM   #25
Montreal , Quebec
One last thing , I chose to use Ontarioans a you wrote it but the proper demonym for someone living in Ontario is Ontarian.
No need to thank me, I just like to educate people like you.
Old 08-05-2016, 08:51 PM   #26
SDP 28 FC's Avatar
2016 28' Flying Cloud
Glen Rose , Texas
I have a 2016 Flying Cloud 28 and cannot find anything that even looks close to fitting the furnace and the manual is no help at all.
These are really nice and well made and fit the water heater perfectly http://www.mud-dauber.com/screens.htm (W100 for 6 gallon). However their M200 is supposed to fit the furnace but doesn't come close.
Anybody know where to go to get one that will fit?
Dealer charged $400 to clean out the dirt daubers.
SDP 28 FC is offline   Reply With Quote
Old 08-05-2016, 09:08 PM   #27
Castaway's Avatar
2012 25' FB Flying Cloud
Celina , Ohio
$67.00 for a screen!!!!!
Castaway is offline   Reply With Quote
Old 08-06-2016, 06:50 AM   #28
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
LOL, Canadians are such polite insulters.
MICHAEL
Old 08-07-2016, 10:00 AM   #29
Cloudland2
davidrrand's Avatar
2016 25' Flying Cloud
Trenton , Georgia
Attachment 268407
My 2016 FC25 rear twin furnace looks completely different from your photo. I wonder how many different models they use?
Thanks!
davidrrand is offline   Reply With Quote
Old 08-07-2016, 10:38 AM   #30
Cloudland2
davidrrand's Avatar
Trenton , Georgia
The manual provided with the trailer says Atwood "hydro flame" AFM series then provides five different model numbers (D16-D35) Have no idea which one I have. Nothing on the outside of unit. Guess I would have to remove all the screws to get to the inside for further identification.
Old 08-07-2016, 11:20 AM   #31
fran&frank's Avatar
2016 27' Flying Cloud
Hartsburg , Missouri
Just measure the minimum size rectangle needed to cover the vents and then pick the best screen option from their dimensions online.
Frank & Fran
2016 27' FC FB with 600 W solar
2016 Ford F150 EcoBoost
Equalizer Hitch
fran&frank is offline   Reply With Quote
Old 08-07-2016, 11:25 AM   #32
Montreal , Quebec
Wink
Thanks for noticing
Old 08-08-2016, 10:11 AM   #33
1967 26' Overlander
Spartanburg , South Carolina
Originally Posted by BeachHouse View Post
Atwood does not recommend them. They say they may reduce air flow. But I have them and have had no problems.
That is pretty ridiculous. The screen I had put on the intake/exhaust of mine has at least 10 times the open area of the air intake itself. It was put on after dirt dobbers or something built a nest inside the intake where it couldn't be seen and caused the side of the trailer to be smoked up. As a safety concern, there is more danger from a malfunction caused by the bugs than the screen. Also, if Atwood can't design their furnaces to operate properly with something to exclude bugs they aren't very smart.
Jacob D is offline   Reply With Quote
Old 08-10-2016, 04:09 PM   #34
Castaway's Avatar
Celina , Ohio
I went to the local hardware store today and bought some aluminum screen for $0.99. I cut it to fit the slotted area on the water heater door and the furnace door. I then took some pf the aluminum strands to tie the screen to the slots. This all took less than 30 minutes.
Gary
Old 05-09-2017, 04:48 PM   #35
SDP 28 FC's Avatar
Glen Rose , Texas
What amazes me about this whole screen "ordeal" is that I called Atwood, Airstream, and the dealer and nobody had a clue about the exact furnace I have. I even had the manual and a number and still nothing. I finally bent and maneuvered the ones I bought and managed to get a fit. I like the idea of hardware cloth cut-to-fit then siliconed in place much better. These are USA made and nicely constructed. http://jcjenterprises.com/
Old 11-08-2017, 03:37 PM   #36
laketime
2014 25' FB Flying Cloud
Hillsboro , Texas
A stupid question.
I don't have one, I never had a wasp or a bug either come in through there that couldn't come in through the door. So why would I need one ?
Careful now... you're foot is entering your mouth. It's about bugs plugging those little thingies that allow air and gas do their work
laketime is offline   Reply With Quote
Old 11-10-2017, 06:05 PM   #37
Jack W's Avatar
1986 34' Excella
Kulpmont , Pennsylvania
Rear furnace wont Light?
I have a 1986 Excella, the front Furnace works great! But the Rear Furnace Runs, But wont Light, no heat? What can be wrong? What can I do to get heat?
Jack W is offline   Reply With Quote
2014 Interstate Bug/Rock screen Support Admin Airstream Classifieds 0 09-23-2013 12:21 PM
Screen door sliding plastic panel, bug guard angellhill Doors & Locks 5 07-18-2012 08:48 PM
Fixing screen door screen wacnstac Windows & Screens 8 04-09-2007 10:35 PM
Bowen/Atwood LP to Atwood LP/ELEC./DSI? 65 overlander Electrical - Systems, Generators, Batteries & Solar 9 12-05-2005 06:10 PM
screen door sliding bug guard M&M CAPECOD Doors & Locks 7 09-21-2004 05:47 PM
