Old 05-10-2015, 07:04 PM   #1
1992 34' Excella
hinton , alberta
asking for help after first trip
I have just returned from a ten day camping trip with my 34 ft airstream 1993 and my 1992 Ford 250. Both bought from original owner and in nice shape but I have a couple questions for you folks with experience.
- my water heater clicks but does not ignite. I intend to clean it up and see if that does the trick- any other suggestions.
- my door is causing a small dent where it attaches to the trailer when propped open. Is there a part I can add there to provide either some cushion or restrict the door from hitting so hard. Could also lop my gkids arms off but that's the last solution
- my old ford has 120000 miles on her and runs like a charm but when first started emits white smoke for 30 seconds. Used no oil in the first 850 miles and runs real clean after the first burst of white smoke
- my truck has a banks eng turbo so runs well. Is there any maintainance required on those units and how many miles should I expect it to last I drive easy and am not in a hurry
- my truck has overdrive and will pull the trailer in OD at 55mph and 2100 rpm if the OD is off RPM jumps to about 2500. which do most folks use.
- when I turn the electrical master switch on there is a humming noise that is always there. is this normal. My manual says leave the switch on unless the trailer is stored fro a long time. The previous owner says he always turned it off to travel or if parked and not in use. What do most folks do with theirs and is the slight hum normal I also have solar panels but that's for a later day when I figure them out
We had a Argosy but had to sell and take a couple years off to do some chemo etc but my prize for kicking cancers arse is my trailer. If any of you get towards Jasper nat park up in Canada give me a call
thanks folks
chuckmac is offline   Reply With Quote
Old 05-10-2015, 07:28 PM   #2
1994 34' Excella
Warren , Manitoba
The "humming" is the univolt power converter and is normal. You may want to replace it with a Progressive Dynamics converter with Charge Wizzard and Intelipower. You will extend your battery life a lot. I installed a PD9245 in my unit. I leave mine on most of the time. Check for spider webs in the burner tube of the water heater. Sometimes it takes awhile for propane to reach the heater if you have replaced the tanks. Lighting the stove top helps. Chris
WBCCI #7394
2002 Chev 2500 HD Duramax
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 05-10-2015, 07:38 PM   #3
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
I can't help you with ine darn question, butvI can offer a warm welcome and a hardy congrats on beating cancers arse. Good for you, now go and enjoy life on the road.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 05-10-2015, 08:58 PM   #4
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Don't worry about the white smoke after the startup, it is unburned fuel ,a little warm up it will go away, I always run my 7.3 at 2300 rpm, it had 185000 miles before it started having problems,3000 mile oil changes....take it easy
Old 05-10-2015, 09:14 PM   #5
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I have the same concern with the door on ours but only if the key is left in the lock. It happens sometime and I think that if the wind caught it or it got pushed back it would put a dimple in the side. I was thinking of removing the catch and making a fiber or rubber pad to add a little thickness to what's already there as some insurance. Haven't done it yet as it's just not that high on my priority list. In my case it is only an issue if I leave the keys in the lock.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 05-10-2015, 09:42 PM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Welcom! Congrats on being healthy! Don't lop off the grandkritters arm. They may actually learn in time...
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-11-2015, 01:04 PM   #7
1978 28' Ambassador
Columbia , Connecticut
Use a pipe cleaner in the venture tube for water heater spiders will build nest in them . As for the door I used a peice of rubber tape where door touches this stopped the dents.
Ducky2 is offline   Reply With Quote
Old 05-11-2015, 01:09 PM   #8
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Aluminum Plunger Door Stop
BambiTex is offline   Reply With Quote
Old 05-11-2015, 01:09 PM   #9
1996 25' Excella
Tillsonburg , Ontario
One of our AS had a small rubber bumper stuck on the trailer. The others have the latch to holds the door open and that provides some buffering as it "slams" against the trailer wall.
We had an Award where the converter started to hum after a year or two....very annoying. We finally sold the problem to someone else. Our Airstreams have not had that problem, but if and when I'll upgrade to a better unit that can float charge the battery
JCW
JCWDCW is offline   Reply With Quote
Old 05-11-2015, 01:10 PM   #10
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Door Latch
Old 05-12-2015, 04:26 AM   #11
2000 30' Excella
2014 30' Classic
Princeton , Iowa
I would leave the Overdrive on. You will get better gas mileage and your engine will last longer at the lower RPM's. My newer converter does not hum. If you call Airstream Tech. in Jackson Center they can tell you. I have found them to be very good and easy to work with.
larryglarson is offline   Reply With Quote
NEWBIE asking for your help IN PURCHASING A 'ONLINE' TRAILER Lady Bird Airstream Motorhome Forums 5 09-21-2011 07:00 AM
NEWBIE asking for your help IN PURCHASING A 'ONLINE' TRAILER Lady Bird Our Community 0 09-20-2011 07:59 PM
Questions after our first long trip - 2005 Classic Wingeezer 2001 - 2005 Classic 15 04-01-2009 05:17 PM
Non WB member asking for help please Cat WBCCI Forum 4 03-03-2007 05:26 AM
Asking for help on equilizer hitch please? Devoman Hitches, Couplers & Balls 9 08-02-2005 04:25 PM
