Kinda like a swim suit that's dry-clean-only.
Aerogel has fascinated me ever since I first heard of it. With it evidently being the lightest, most efficient insulation ever developed, I too thought it would be fun to install in an Airstream, if only there were a thermal break as efficient for the ribs, or if the ribs were carbon fibre or something.
The basic problem at hand, beside the cost of Aerogel, procuring it, and working with it, and not having it shatter on you, is that ultimately you are installing it in a shell made of Aluminum, one of the most efficient conductors out there. And if you really wanted to maximize your thermal efficiency, Aluminum would not be the material of choice, and you would want thicker walls, and smaller, more efficient windows, and pretty soon you end up with something not at all like an Airstream.
But wouldn't it be great if Airstream trailers were truly four season? It's a trick, like how to make a tank light-weight enough to fly, or healthy vegetables that taste like chocolate, or smokeless fire-wood that won't burn you.
