Old 10-11-2014, 06:28 AM   #15
Originally Posted by nickclifford View Post
J, can the ride height be raised when installing new axles ? thx for the advice
We change the starting angle on new axles.
Usually, the trailer is raised about 3 inches with them, from worn out rubber rod height.
Old 10-11-2014, 09:02 AM   #16
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
any quick thoughts on patching this floor wood rot ?
I also raised the axles 3" when I installed new. (I welded). (I used this as an opportunity to fix the frame sag by welding in 6' x 3" angle to hold the frame straight)
There is a bolt in kit available to raise the axles 2".
The ONLY floor rot I have found. Anyone have a quick fix idea? WILDRTEXAS Repairing/Replacing Floor &/or Frame 8 03-18-2010 06:30 AM
how much rot is too much rot? adwriter73 Repairing/Replacing Floor &/or Frame 56 02-28-2010 11:05 PM
Patching floor help Ifihadtime Repairing/Replacing Floor &/or Frame 6 06-06-2007 09:04 PM
patching the floor and how to revit on the inside SWAIN Repairing/Replacing Floor &/or Frame 5 04-17-2006 12:55 AM
To rot or not to rot. Charming Wino Repairing/Replacing Floor &/or Frame 15 03-01-2004 10:39 PM
