Old 03-03-2014, 04:51 PM   #1
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
Anticipating axles!
Got axles removed yesterday , wire wheeled & painted frame in wheel well area . I also did more polishing today... Taking advantage of the hangar space! Hopefully new axles will be here this week!
Cochese is offline   Reply With Quote
Old 03-03-2014, 04:53 PM   #2
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
Sorry , here are pics!Click image for larger version
Name:	ImageUploadedByAirstream Forums1393887171.690168.jpg
ID:	206766Click image for larger version
Name:	ImageUploadedByAirstream Forums1393887190.115823.jpg
Old 03-03-2014, 05:00 PM   #3
Air-Texas's Avatar
2004 34' Classic S/O
Waldorf , Maryland
Looking real nice!
Mike, Miho &
Dallas the Bourbon Boxer
S/OS#069
TAC # TX-33
WBCCI #5702
AIR #60387
"Eva" 2004 Classic Limited 34' S/O
"Wall-E" 2012 Ford F250 King Ranch
Air-Texas is offline   Reply With Quote
Old 03-04-2014, 06:35 PM   #4
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
After going back and forth on wether to drop the belly pan to remove old insulation& nasty decayed vermin, I think now is the time to do it! Not looking forward to drilling out hundreds of rivets& god knows what else I'll run into! I have 4 weeks to do axles, belly pan, & finalize polishing before my first music festival !
Old 03-04-2014, 06:52 PM   #5
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
You can do it and as for what lays in the belly pan, we are waiting with baited iPads so drill them and drop it then yes take lots of pictures! We have been there and the nastiness is always good to remove! Luck to you.
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 03-04-2014, 07:13 PM   #6
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
I will do my best to document the carnage! I am putting 1 inch foam insulation w/ air gap, also painting frame
Old 03-05-2014, 02:48 PM   #7
1966 17' Caravel
I have the 2 inch foam with the 1inch for the air gap. Just need the weather! Will keep watching your progress.
Cliff
Old 03-05-2014, 04:07 PM   #8
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
I'm going to hit it hard this weekend, I'm getting a helper for the rivet drilling!
Old 03-09-2014, 07:47 PM   #9
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
Productive weekend... Drilled center rivets in belly pan& looked inside, everything was so clean no falling insulation & paint was very good on frame! Amazingly good condition so I'm going to leave it alone! Ran new brake wire& new 7 way harness to clean up some halfass wiring done at some point. Finally got to run my electric jack wire inside the pan. Still no axles yet!
Old 03-09-2014, 07:55 PM   #10
1966 17' Caravel
Awesome glad to hear that all looked good under the belly pan! I waited awhile on my axles too!
Cliff
Do I need new wheels if I'm getting new axles? awetsch General Repair Forum 31 03-17-2014 02:42 PM
Towing with Bad Axles CF Av8or Axles 15 02-11-2012 06:19 AM
