Old 06-25-2016, 07:12 AM   #1
Picinisco's Avatar
1977 Argosy 24
Gilbert , Arizona
Antenna removal and blank off
I want to remove the TV antenna and blank off the hole. Any tips?
Picinisco is offline   Reply With Quote
Old 06-25-2016, 07:44 AM   #2
Picinisco's Avatar
1977 Argosy 24
Gilbert , Arizona
Also, standing/crawling on the roof, are there any no-go areas?
Cheers....John
1977 24ft Argosy - sold.
Old 06-25-2016, 09:46 AM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Don't put any weight on the end cap!
Old 06-25-2016, 10:09 AM   #4
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Get a round aluminum disc. Caulk and rivet it over the void.
Old 06-25-2016, 10:21 AM   #5
aircraft1's Avatar
1977 27' Overlander
Winnetka , California
Do you have access to the interior? if you do, I recommend you use solid rivets instead of Olympic rivets. If you must use Olympic rivets make sure you install them wet with sealant and be sure the plate/doubler is also buttered with good sealant. easy job. good luck.
aircraft1 is offline   Reply With Quote
Old 06-28-2016, 10:02 PM   #6
Durango , Colorado
If your antenna is the Wingard bat wing crank up antenna you can order an exact cover plate with matching screw holes from Wingard. I removed the whole mounting assembly but I would suggest leaving your coaxial cable under the skin where you can access it if you ever decide to add a different antenna. I removed mine for a solar panel installation. Hope this helps.
You can PM me with further questions.
Ken
pkm123 is offline   Reply With Quote
Old 06-28-2016, 10:32 PM   #7
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Convert it to a wifi antenna instead!!!
Old 06-29-2016, 03:03 AM   #8
Picinisco's Avatar
1977 Argosy 24
Gilbert , Arizona
Now that's an option.
Old 06-29-2016, 03:12 PM   #9
drboyd's Avatar
1978 25' Tradewind
Actually, all the plastic stuff on mine was toast from 38 years of UV. I found a NOS identical antenna, and the first thing was to coat all the exposed plastic with a coat of Krylon fusion.
I chopped off one leg of the antenna and bolted on (2) yagi wifi antennas. Extension cables then feed down to two wifi booster adapters like this.
I'm on the road for another 6 weeks or so, but home is in Chandler; give me a holler if you want to pursue this further.
Antenna Removal & Replacement with Cell/Wifi Antenna BoldAdventure Electronics & Connectivity 10 08-14-2017 07:24 AM
wanted key blank for 69 Overlander bgow 1965 - 1969 Overlander 4 10-04-2015 11:15 PM
A blank slate: batteries and converter 66replica Batteries, Univolts, Converters & Inverters 2 09-02-2014 12:42 PM
Blank slate William8979 Electrical - Systems, Generators, Batteries & Solar 13 02-20-2005 09:28 AM
Blank space with adds perminent? rfield54 Forum Admin, News and Member Account Info 14 02-17-2005 08:19 PM
