Old 06-24-2019, 06:50 PM   #1
2012 28' International
Victoriaville , Quebec
Antenna reception
We have a 2019 FC 25' FBT with a King antenna. With the antenna booster at on we scan the auto program and the front TV gives us four channels which is acceptable where we are.
When we scan the auto program on the rear TV in the bedroom the result is zero channel.
I took a look at the connections and everything is perfect.
Why don't we have the same number of channels either front and rear TV?
SGosselin is offline   Reply With Quote
Old 06-24-2019, 08:01 PM   #2
2018 19' Flying Cloud
Coeur d Alene , Idaho
Assuming the connections are all okay (big assumption as one never knows what's been done inside the walls), then double check that you when you invoke the scanning function you have specified "antenna" and not "cable".
Dale & Jane
2018 Flying Cloud 19
2003 Dodge Ram 2500 Quad Cab Diesel
KelloggKid is offline   Reply With Quote
Old 06-24-2019, 09:26 PM   #3
Mollysdad's Avatar
First, make sure the antenna booster is on.
Make sure both TV's are set to "antenna".
Mine show the same channels.....not many.
Antenna Removal & Replacement with Cell/Wifi Antenna BoldAdventure Electronics & Connectivity 10 08-14-2017 07:24 AM
No reception on antenna. TomS Audio, Video & TV 2 05-30-2017 07:34 AM
No reception. Cable nor antenna Native143 Audio, Video & TV 8 08-30-2016 10:00 AM
jack antenna reception gnowlin Electronics & Connectivity 18 09-04-2015 09:54 AM
No TV reception with Winegard antenna JMBORST Audio, Video & TV 6 05-25-2014 06:44 AM
