Old 08-04-2010, 06:49 AM   #1
1988 32' Excella
Anderson , South Carolina
Antenna problem from new camper
We have a 1988 Excella. The antenna crank is stuck. I have read all the answers on the forums but WD40 does not help. We are new to this. How do you remove the crank and where doi you find one to replace it with? Is there any way to raise the antenna without it?
dcslater is offline   Reply With Quote
Old 08-05-2010, 11:22 PM   #2
Dan@LED4RV's Avatar
Denton , North Carolina
sounds like gears
It sounds like the gears might be messed up. Get on top ( have to go up on the side) and you will see a black cap with two screws holding it down. The cap may even be broken. That cap and the gears inside have to be in good working order for it to go up. When you get up there you will see what I'm talking about.
Out-of-Doors Mart and Inlandrv have the parts in stock
Dan
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Antenna base removal problem 63air Phone, CB & Ham Radio 8 03-01-2010 04:12 PM
What is it: Antenna and? bmklawt Audio, Video & TV 3 12-18-2008 11:32 PM
Antenna silverlassie Audio, Video & TV 19 05-01-2004 01:02 PM
Antenna Lee Pace Audio, Video & TV 3 09-21-2003 08:55 PM
Battery problem or converter problem Paul Daugherty Airstream Motorhome Forums 31 07-01-2003 06:16 PM
