Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 02-26-2009, 08:53 PM   #41
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
I learned something new too. I knew about rear seperation but not the repair and elephant ears. Thanks Twink.
Thanks also to bullet4sale for being honest. We need more dealers like him.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 02-27-2009, 07:18 PM   #42
7751
Torii's Avatar
1975 25' Tradewind
Huntington Beach , California
Originally Posted by AlbertF View Post
Paula's raised an important point. Floor rot at the rear may often be a precipitating factor for rear separation.
Just re-bolting the channel to the frame is merely an interim repair, because attaching the shell/lower C channel to the frame at only one point won't work for long. The aluminum channel is simply not strong enough for one bolt on each frame rail to do the job. The shell/channel needed to be fastened more or less continually to the perimeter of the floor to spread the load out. And that requires a solid floor. Otherwise, the problem will come back, sooner or later.
Inland Andy has thoroughly detailed the an effective approach elsewhere.
I would add that it should probably be done at the same time as replacing the rotted bathroom floor . . . and I see a bathroom restoration in my future. I'm just hoping to put it off for another couple of years. At least the climate is quite dry here, and things don't rot very fast.
Andy's detailed approach is referenced here although it doesn't seem to live on these forums anymore...
I am currently replacing the rear floor section and my Tradewind did not have any of the signs of rear-end seperation although the floor did rot on the back edge. Mine was either done right originally or fixed later because it already fits Andy's description of a proper repair.
Torii is offline   Reply With Quote
Rear End Sag Not Separation airstream74 Repairing/Replacing Floor &/or Frame 44 12-27-2006 09:31 PM
Rear Separation and Rear Sag on my '72 mello mike Axles 17 06-16-2005 01:58 PM
Rear End Separation 76argosy26 Repairing/Replacing Floor &/or Frame 6 09-13-2004 09:32 PM
The dreaded rear end sag/separation Craig Repairing/Replacing Floor &/or Frame 5 04-23-2004 06:52 AM
Rear End Separation Questions... Morning Dew Repairing/Replacing Floor &/or Frame 24 02-03-2004 10:22 PM
