Old 03-31-2012, 11:00 PM   #1
bbqmama's Avatar
1967 20' Globetrotter
Broomfield , Colorado
Another mystery part!
Hello all!
We have a 1967 globetrotter and descending from the top frame of the battery compartment is about 6" of semi clear (it's old so now cloudy) plastic tubing. It's as if it's there to drain something from the inside of the wall.... We'd like to know what it is as we're tempted to remove it to avoid any more potential moisture getting in to the batteries.
Any ideas? I've included some pics....
Thanks much!
ID:	154731   Click image for larger version
bbqmama is offline   Reply With Quote
Old 03-31-2012, 11:08 PM   #2
Ifihadtime's Avatar
1981 27' Excella II
Lynnwood , Washington
Not sure but it looks like it could be a drain from an air conditioner if it has one or maybe an ice box?
Ron
81 Excella II
I am always doing that which I can not do, in order that I may learn how to do it.
Ifihadtime is offline   Reply With Quote
Old 03-31-2012, 11:11 PM   #3
bbqmama's Avatar
Yah, it does doesn't it? Hadn't thought of that optin! I don't know I'd there was air con at one point but nothing indicates there was either on roof or in the window above the battery compartment... The fridge etc is all on the other side of the trailer which I think was the original setup......
Old 03-31-2012, 11:51 PM   #4
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
It also could be a vent for the battery. On my 69 it had a hose in the battery compartment that went up and had a small screen. It was a vent.
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
arodriguez60 is offline   Reply With Quote
Old 03-31-2012, 11:57 PM   #5
1974 Argosy 20
Kooskia , Idaho
I am almost positive it is the battery vent. At that time they had a little plastic thingie which fit over the tops of the battery caps, and had a hole in one end. The plastic tube went from that hole to the outside (on my 71 Caravel it went to a screen just above the battery door). You can decide on your own what you wish to do with it.
Old 04-01-2012, 04:17 AM   #6
Baltimore , Maryland
vent tube for the battery...
Old 04-01-2012, 08:05 AM   #7
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
The battery would have had a molded cover over the top. The tube goes in a hole in the cover to vent the battery
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 04-01-2012, 08:12 AM   #8
Originally Posted by bbqmama View Post
Hello all!
Thanks much!
Back then, for the 1967 model, the battery was mounted in a side compartment.
It also had a plastic cover that was part of the battery hold down.
That clear plastic tube was then inserted into the plastic cover so that the battery fumes would vent outside.
Old 04-01-2012, 08:16 AM   #9
Hello all!
Thanks much!
The outside cover, immediately above that battery compartment has a small plate with a hole in it.
From your photo, it looks like someone inserted a screw into that center hole.
That screw must be removed if your going to use that vent.
Old 04-01-2012, 10:48 AM   #10
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
One of my favorites:
Name That Part!!
Old 04-02-2012, 02:59 PM   #11
bbqmama's Avatar
Ah ha! I knew you all would know! Thanks so much for the feedback.... We just put in a set of lifeline agm batteries in there.... Sounds like I need to open that vent area up again so any gases can escape? Or do the Agms not need a vent since they're sealed?
Old 04-02-2012, 03:14 PM   #12
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Vent it. No battery is really trustworthy.
Vintage Trailer Part #s and Manuals Exchange LarryGlover Vintage Kin 8 02-12-2016 08:04 AM
Another Airstream dealer Dropping Out? Foiled Again Off Topic Forum 12 03-24-2012 07:58 PM
Need help immediately on brake hose part mumbers dadstoy Classic Motorhomes 3 03-23-2012 05:09 PM
Mystery Drain Line DearArgosy Plumbing - Systems & Fixtures 6 03-18-2012 05:46 PM
Another tow capicity question Castaway Tow Vehicles 4 03-15-2012 11:26 PM
