Old 07-17-2017, 08:54 PM   #1
2017 25' Flying Cloud
Panama City , Florida
Another leak, bathroom 2017 25FB
Not sure if the video loaded correctly but looking for some help to see where this leak may be coming from. When it first leaked a couple months ago, the dealership sealed up the vent fans on both sides. It only leaks when it really, really downpours. Almost as if the water is pooling somewhere. Any ideas? Thanks y'all!
OSCS is offline   Reply With Quote
Old 07-17-2017, 08:58 PM   #2
In case the video didn't load correctly.
ID:	289726   Click image for larger version
Old 07-17-2017, 10:38 PM   #3
2016 25' International
Deerfield , Massachusetts
I have EXACTLY the same leak. Only appears in a complete downpour.
ID:	289748Click image for larger version
thiel is offline   Reply With Quote
Old 07-18-2017, 08:46 PM   #4
Attachment 289748Attachment 289749
Thanks Thiel. If I find anything, I'll let you know!
Old 07-18-2017, 09:04 PM   #5
Traveler
TravlinMan's Avatar
2017 25' International
Staunton , Virginia
Hm. I dunno. I have a 25fb and one time.. just once... I found drops after a rain on the floor under that very spot. Course, I had left the fan vent open... so I assumed it was that. Now I gotta keep an eye out. Cause that ain't good. Mildew and mold grow quick.
TravlinMan is offline   Reply With Quote
Old 07-18-2017, 09:08 PM   #6
In a downpour I found that maybe 10 drops had dropped. Previously I had seen a small telltale drip mark and nothing more.
Old 07-19-2017, 01:23 PM   #7
Rochester , New Hampshire
Sounds like a gasket leak within the fan /vent itself.
mrsmup is offline   Reply With Quote
Old 07-19-2017, 01:32 PM   #8
2014 25' FB Flying Cloud
Grand Rapids , Michigan
Tagging into this thread as well, though I wish I was offering a solution.
We had this exact leak form after a massive hail/rainstorm in Idaho a few weeks ago. One thing I did notice was that I also had water drop down directly from the fan when it was turned on during our investigation, leading us to think there was a pooling issue as well.
We were planning to go up top and look at the sealant around that vent the next time we got the trailer back from storage, but it sounds like your dealer already looked at that possibility.
MIFC is offline   Reply With Quote
Old 07-19-2017, 03:13 PM   #9
Tbeck11931's Avatar
1991 34' Limited
2013 23' FB Flying Cloud
Conroe , Texas
I would check the seal job they performed. I would also look in at least a 4 foot radius from where the leak appears inside. Is it sitting in a level position? If you have the tongue a little high then it could be coming from a more forward location on the roof. Then it finds the path of least resistance which could be far away from the real problem. Unfortunately they say it's built like a Aircraft when it's really not. We seal all our seams before riveting together. When you do that properly then you won't get water intrusion anywhere even at 400 kts.
Thomas
Tbeck11931 is offline   Reply With Quote
Old 07-25-2017, 08:56 AM   #10
2016 25' Flying Cloud
2003 22' International CCD
2004 28' Safari
Sahuarita , Arizona
We had a similar leak in the same area. Turns out it was where the solar wiring entered the top.
Suggest the dealer pressurized leak test. $200 but well worth it to find all the leaks before they can cause real damage. T
AzAirstream is offline   Reply With Quote
Old 07-12-2018, 11:12 AM   #11
Houston , Texas
We have also Flying Cloud 2017 25FB and this post and video describes exactly what is happening to us at the same spot in the bathroom, it really needs to downpours for the leak to show, we are on the road at the moment, any suggestions apart from the ones in these thread?
Sol_Elf is offline   Reply With Quote
Old 07-12-2018, 01:36 PM   #12
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Hi Sol_Elf,
Please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team.
You can also reach Airstream Customer Service and Technical Support at customer_support@airstream.com
Thank you.
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Old 07-12-2018, 10:42 PM   #13
Houston , Texas
Thanks for the response AirstreamInc, info sent.
Originally Posted by AirstreamInc View Post
Hi Sol_Elf,
Thank you.
Old 11-02-2018, 11:04 AM   #14
Waco , Texas
Hello Friends,
We are having this exact issue with our 2017 25FB. Did you all find a solution?
Thank you,
Theresa
emelaich is offline   Reply With Quote
2013 vs 2017 25fb differences, is ducted a/c worth it? Bambii 2016 - Current International 19 04-16-2017 06:31 PM
NorCal : 2017 Olema Spring Rally April 7-9, 2017 (formerly at Casini) HootMon-Frau Forum Rallies & Meet Ups 14 04-01-2017 01:46 PM
Teak Mats for 2017 25FB. interstateflyer 2016 - Current International 1 01-03-2017 03:16 PM
ZAMP 3 Port Roof Cap Prewire System on 2017 25FB Questions interstateflyer Generators & Solar Power 14 12-15-2016 07:55 PM
Run away from 'dream' 25fb w/ leak? irm Repairing/Replacing Floor &/or Frame 21 12-12-2012 11:56 AM
