Old 05-27-2016, 12:22 PM   #1
2012 30' International
Livingston , Texas
Another Fillaform Question
Does anybody know if fillaform develops on the inside of the outside skin? I have a pretty bad problem, mostly around my side markers and wonder if the fillaform is growing between the walls where I can't see it. Or does it only grow under the clear coat? Thanks!
glenrms is offline   Reply With Quote
Old 05-27-2016, 01:59 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Filiform corrosion by definition only forms under a coating in the presence of moisture. So yes, it is possible for filiform corrosion to develop on the inside surface of the outside wall panels— if the aluminum is clear-coated on both sides.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 05-27-2016, 02:38 PM   #3
TheCabin's Avatar
2013 25' FB International
Liberty Corner , New Jersey
There are pictures of filiform growing from a panel edge riveted under the adjacent panel shown on the corrosion thread. I will look later for the posting but it is within the past few months. But filiform requires a break in the organic coating on the metal; you need the organic coating.
TheCabin is offline   Reply With Quote
Old 05-27-2016, 04:09 PM   #4
Gainesville , Florida
It's only cosmetic so it won't fall apart from the inside if that is your concern.
Old 05-27-2016, 05:35 PM   #5
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I think the question is, does the inside panel have any coating? If so there could be filiform corrosion, if not then no filiform. Whether it's likely to be a problem is unlikely.
Doug and Cheryl
Old 05-27-2016, 05:39 PM   #6
TheCabin's Avatar
When it comes to our AS's, ignorance is bliss. Any deeper understanding than that may cause unhappiness.
Old 05-27-2016, 07:36 PM   #7
TheCabin's Avatar
Here is a link to filiform that grew out from under a sheet which could occur on the inside if there was a crack in the organic layer.
http://www.airforums.com/forums/f142...ml#post1726310
I too find myself wondering what unpleasant surprises are hidden from sight due to the silly methods and parts AS uses during assembly.
Just another hello from another newbie nanaenes1 Member Introductions 7 12-16-2014 11:45 AM
Another trip, another repair swanky Classic Motorhomes 6 07-07-2009 02:24 PM
Another Winterizing Question JWest Plumbing - Systems & Fixtures 2 11-04-2002 07:01 AM
Another Catalytic heater question Ken J Furnaces, Heaters, Fireplaces & Air Conditioning 4 10-26-2002 10:57 AM
Another Power Jack Question. 68 Suburban Jacks, Stabilizers, Lifting and Leveling 3 10-15-2002 10:23 PM
