04-04-2021, 12:55 PM
#121
Fonthill
, Ontario
As promised, here is a picture of the power centre I built for the Airstream. The power converter/ charger sits inside.
Now that the floor has been re-repaired using Starboard, I’m warming up the linoleum flooring I rough cut while the shell was still off.
Here’s the final roll out without any trimming. The wrinkles are from being rolled up for the last 5 years. Once the flooring has had a chance to relax a bit I’ll do any fine trimming if required.
Although it seem like I know what I'm doing, I'm just standing on the shoulders of giants who have done this before and kindly posted their journey.
Cheers,
Jack
73's VE3ZPW
04-04-2021, 12:57 PM
#122
Fonthill
, Ontario
For the record, the AC side of the power centre has a cover on it when installed to prevent any accidents.
Cheers,
Jack
73's VE3ZPW
05-04-2021, 02:42 PM
#123
Fonthill
, Ontario
Aluminium inner wheel wells installed and rear bulkhead dry fitted. Now to cut out a few more bulkheads and start installing them.
Cheers,
Jack
73's VE3ZPW
05-04-2021, 03:03 PM
#124
1966 22' Safari
Fredericksburg
Looks well thought out. Now there’s another giant’s shoulder I can stand on. Thanks for the pictures. Take care
05-04-2021, 04:24 PM
#125
2021 30' Flying Cloud
2020 25' International
minneapolis
Keep the photos coming
- Stewart
05-09-2021, 09:23 PM
#126
Fonthill
, Ontario
Cheers,
Jack
73's VE3ZPW
05-09-2021, 09:34 PM
#127
Fonthill
, Ontario
Got some more bulkheads cut out. Once the first one is cut to size and shape the rest are easy using the router with the first as a template. Now if only I could find some decent plywood for the last 2 required. Any I could find has been priced astronomically by the COVID induced supply shortage.
Cheers,
Jack
73's VE3ZPW
05-11-2021, 01:33 PM
#128
Fonthill
, Ontario
Forgot to add pictures of the door edge
Outside edge
Inside edge. You can see where the repair was made. The previous hole was so large the the extrusion had broken in 2 and was being held together by the sheet aluminum. Lots of welding, grinding and more welding to get it back to where it needed to be.
Cheers,
Jack
73's VE3ZPW
05-11-2021, 01:57 PM
#129
Fonthill
, Ontario
Today’s session was to install the retaining brackets for the drop down dinette table. Bought the hardware from VTS. Problem was that the retaining brackets had to be mounted on top of the screen window frame but had to remain removable. After pilot holes were drilled, I broke out my rivnut tool. With the appropriate size hole I inserted the rivnut.
Rivnut
Rivnut on instal tool.
After squeezing the handle, you can see how the rivnut expands around the hole.
Rivnut mounted
Machine screw fitted.
Because the lower holes of the bracket were below the frame, I cut drilled then riveted a 1/8” bar just under the frame. Since the bar could remain, I drilled and tapped the holes for the screws.
Although not common, the rivnut is quite handy for mounting items to the inside to the Airstream that need to the be screwed off and on again.
Cheers,
Jack
73's VE3ZPW
05-22-2021, 07:29 AM
#130
Fonthill
, Ontario
Dinette is all done, now for cushions luckily not my job.
Folded in the down position just in case an extra bed is needed.
Luckily it’s just the 2 of us. Kids are all grown and on their own.
Cheers,
Jack
73's VE3ZPW
12-10-2022, 03:54 PM
#131
1966 28' Ambassador
St Catharines
, Ontario
Excellent Work Jack!!!
I will send you some shots of my 1966 !
Thanks for your help today, Steve
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
