Old 08-24-2019, 01:20 PM   #1
Hermes's Avatar
2016 28' International
Trois-Rivieres , Quebec
An Essential Airstream Tool : The Humidity Meter
With hundreds of holes and openings in an Airstream, it's a good idea to be vigilant and make sure there are no water leaks. Let's not forget that Airstreams are built with floors that will deteriorate when wet (it's called rotting).
Reading a post like the following about a rotting floor in relatively recent model is simply gut wrenching:
http://www.airforums.com/forums/f44/...m_medium=email
There have been posts years past on humidity meters, but today there are models available that are without sensor pins, that can make a reading up to 3/4" deep into a surface, etc.
Any suggestions on what you are using and how effective it has been for you? How often do you take readings and where are the sensitive areas that need to be monitored regularly (if any)? Any happy ending stories?
2016 International Signature (Oyster/Ebony), Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap,
DIY Solar: 500W Renogy panels, AM Solar hardware, Blue Sky MPPT controller and monitor, 470ah (C20) Rolls battery bank.
Hermes is online now   Reply With Quote
Old 08-25-2019, 05:05 AM   #2
2017 30' International
Charlotte , North Carolina
Interesting question.
Bump
Al U. Minium is offline   Reply With Quote
Old 08-25-2019, 05:19 AM   #3
dznf0g's Avatar
Oswego , Illinois
I have 12 doberman brand water alarms placed around the perimeter of the shell. It is my early warning system for floor protection. My moisture meter I for diagnostic work after an alarm has sounded.
-Rich-
Old 08-25-2019, 06:34 AM   #4
fran&frank's Avatar
2016 27' Flying Cloud
Hartsburg , Missouri
I think you need a model with sensor pins to get through your vinyl floor or carpet, I don't think a model without pins would be effective in this circumstance.
Frank & Fran
2016 27' FC FB with 400 W solar
2016 Ford F150 EcoBoost
Equalizer Hitch
fran&frank is offline   Reply With Quote
Old 08-25-2019, 06:37 AM   #5
dznf0g's Avatar
Oswego , Illinois
I agree. In addition, keep a piece of pine in the garage where it is always dry. This is for comparison to your readings of the AS floor. I believe, depending where you live that one can become alarmed unnecessarily with a floor reading. The meters are pretty sensitive. In my area, the normal humidity makes for a 6% moisture reading, due to humidity penetrating its surroundings. The pine board in the garage (always dry) is your baseline.
Obviously, different in AZ and different in MS.
-Rich-
Old 08-25-2019, 09:44 AM   #6
Silver Star
rucos's Avatar
1970 23' Safari
Victoria , British Columbia
I Think if you wanted a baseline board, Id also keep one in a drawer or back of a cabinet inside the trailer as this would tell you your baseline inside the trailer.??
rucos is offline   Reply With Quote
Old 08-25-2019, 10:26 AM   #7
Watertown , Massachusetts
More info?
Can you give us more information on the module you use, and where and how you install them?
sallye is offline   Reply With Quote
Old 08-25-2019, 10:39 AM   #8
PEN
2019 27' Globetrotter
Bryant , Arkansas
Following
Paul & Deb
PEN is offline   Reply With Quote
An Essential Tool - a 7 pin connector tester Alphonse General Repair Forum 17 11-04-2014 07:43 PM
New Airstream - Essential Accessories txairdream Airstream Lifestyle 41 11-13-2013 05:56 PM
"The 7 essential Airstream websites" article on new RV site Squob Airstream "In the News" 7 09-24-2008 03:44 PM
How essential is the sway bar? 63overlander Hitches, Couplers & Balls 25 11-03-2004 06:11 AM
essential tools maznblu On The Road... 14 07-08-2002 02:23 PM
