Old 11-08-2017, 03:32 PM   #1
S/O#080
Tschupp's Avatar
2006 30' Classic S/O
Tucson , Arizona
AMP hour meter shows 0 on battery charge
After one week in storage outdoors in Tucson I returned to trailer and noted the meter was dark did not light up with status button depressed. Plugged into tow vehicle and meter went through startup but battery charge level remained at 0. I am very new and need to know what my process should be to figure out what is going on. Or maybe it's nothing and I need to relax. Thanks for any help. Carolyn
Tschupp is offline   Reply With Quote
Old 11-08-2017, 03:49 PM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
First question: What meter are we talking about? Since you don't show a trailer in your description it's a bit tough to guess. Assuming it is the solar readout that often is near the stove .... which reading are we looking at?
Best guess, the batteries got left in a state that drained them flat. Next step is to get them charged back up. Plugging into shore power likely will do the trick. After that it's time to dig a bit to work out what went wrong.
Old 11-08-2017, 03:51 PM   #3
2007 22' International CCD
A few possibilities:
Use/Store switch (usually by the door) is in "store" so the battery monitor can not see battery condition. Try setting to store, see if you hear the 'clunk' of the relay closing, then check again.
Battery could be well and truly dead from something left on and draining it. That will involve checking battery with a voltmeter...
Rich, KE4GNK/AE
'The Silver HamShack' (2007 International 22FB CCD 75th Anniversary model)
2012 shortbed CrewMax 4x4 Toyota Tacoma TV with more antennae on it
Old 11-08-2017, 04:02 PM   #4
Half a Rivet Short
Hi
Actually on most modern AS trailers, the solar monitor panel will show you the state of the battery in either the use or store position .... It's AS so you can never say never ....
Old 11-08-2017, 09:12 PM   #5
S/O#080
Tschupp's Avatar
Tucson , Arizona
Thank you for answering . The rig is a 2006 Airstream Classic W/Slide. The monitor I was looking at is the one that tells me The battery charge status is indeed by the stove in galley. By the door is switch for overhead lighting and for outdoor dome light. Not sure if those are what is referred too. As I don't have power st storage think I will take rig to KOA plug on and see what is up. I don't want to leave batteries depleated. Thank you for your time and knowledge. Carolyn
On The Go Portable Dual Bed Deionizer Tanks & TDS Meter Road Dog Airstream Classifieds 0 05-16-2017 12:33 PM
Help! After storage, no battery power but Monitor shows green barrettjl Electrical - Systems, Generators, Batteries & Solar 6 05-28-2013 10:13 PM
Hobbs hour meter for Onan 4.0 needed Astrodokk Classic Motorhomes 3 01-01-2013 03:33 PM
Amp Hour conversion?? beerrun'r Batteries, Univolts, Converters & Inverters 10 03-04-2008 08:24 PM
Hour meter for Honda EU2000i walter1 Generators & Solar Power 7 02-01-2008 05:48 PM
