Old 02-16-2018, 05:00 PM   #1
wareaglewalt's Avatar
2017 25' Flying Cloud
Bushnell , Florida
Ammonia(?) odor in closet
2017 Flying Cloud 25 FB. To my male nose it first started smelling like a dead animal, but has since (and according to my bride's much better sense of smell) is like ammonia. The closet is next to the fridge. I took off the shelf at the bottom of the closet and could smell some ammonia kinda faintly but it's there. Stupid question but would an ammonia leak manifest itself at some point in liquid form? I'm not sure if anyone has experience with this. I took a picture of what it looks like under that shelf next to the outer wall. One other item of note is last nite the fridge raised to 38 degrees but not 100% sure if that was from putting groceries in earlier in the day or not. The fridge temp started dropping last nite and is back to 32 now.
Suppose we'll need to be taking a trip to the Airstream dealer in Gulfport.
Any ideas are appreciated!
wareaglewalt is offline   Reply With Quote
Old 02-16-2018, 05:04 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
sounds like a fridge leak.
CRH is offline   Reply With Quote
Old 02-16-2018, 05:36 PM   #3
1989 34.5' Airstream 345
Ebro , Fla Panhandle
Yes fridge most likely.
Do be careful if you are staying aboard. It can cut loose and really gas out the space. I'd suggest keeping the roof ehhaust fan on to move it out of your living space.
It's lighter than air and will gather near the ceiling.
Cheers Richard
tevake is offline   Reply With Quote
Old 02-16-2018, 06:57 PM   #4
Long Island , New York
Ditto -- prob the fridge, and be careful per earlier comments.
Yes, adding groceries to fridge can raise temp. Best to pre-chill everything if possible especially in the summer.
If the fridge continues to hold a consistent cold temp, the smell could be something else IMO. Our fridge in the old AS failed, with ammonia smell, but it failed quickly.
I would call the dealer ASAP as they may have good suggestions.
Good luck!
Peter
Old 02-17-2018, 11:07 AM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Are you sure it is Ammonia and not Propane?
IMHO the unit would not cool if it loses ammonia
Old 02-17-2018, 12:15 PM   #6
mandolindave's Avatar
It's often hard to diagnose stuff from afar.
In 2005, I had a 1973 fridge leak. You could visibly see the gold/green oozing out of a fitting. The smell wasn't bad inside, as the business end of the fridge is more or less outside. The fridge could still freeze milk an eggs at a low setting.
Supposedly…The ammonia gas is very dangerous. I wouldn't want to sleep in the trailer.
As mentioned…it could be propane. And again, I wouldn't want to sleep in the trailer.
mandolindave is offline   Reply With Quote
Old 02-17-2018, 01:10 PM   #7
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
We experienced a bad smell in that same area, and it turned out to be a problem with that backflow valve, causing us to smell gases from the black tank. Pee can smell like ammonia.
"A good traveler has no fixed plans, and is not intent on arriving." - Lao Tzu
SeaLevel is offline   Reply With Quote
Old 02-18-2018, 05:03 PM   #8
Bushnell , Florida
Is this the backflow valve?
Old 02-18-2018, 05:16 PM   #9
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Yes. It is actually (at least in my trailer) a check valve to allow air into the sink drain when the gray tank is dumped in case the stoppers are in place. It is not supposed to allow air (with accompanying odors) to enter the living area of the trailer, but it can if it gets a piece of food waste trapped in it.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Al and Missy is online now   Reply With Quote
Old 02-18-2018, 06:50 PM   #10
Bushnell , Florida
So pardon my ignorance but do I disassemble this thing?
Old 02-18-2018, 07:03 PM   #11
IIRC the top screwed off on mine. There was a flexible flapper diaphragm inside. But that was a couple of years ago and yours may be different from mine.
Al
S/OS #004
Old 02-18-2018, 07:06 PM   #12
SeaLevel's Avatar
Jupiter , Florida
Sorry, I got the terminology wrong. I was referring to the check valve that is part of the black tank flush plumbing. I had Airstream (Jackson Center) fix it when we took the trailer in for some warranty work.
Old 02-19-2018, 07:33 PM   #13
2017 23' International
I had this same smell it was a water leak that got under the vinyl floor and it mildewed. Smelled like ammonia. Are there any black spots on the vinyl floor ? Lift up the floor / bottom of the closet and see if your water pump is below the bottom. Very possible it leaked (mine did) and caused this smell (mine did)
The older I get , the better I was.
troubadour1 is offline   Reply With Quote
Old 02-24-2018, 11:53 AM   #14
Bushnell , Florida
Follow up...
I failed to mention a key aspect to this odor. it was intermittent. It would come and go every half hour or so. Anyway, for those who might be interested, it has apparently gone away once we dumped our tanks. Our black tank was showing 85% so who knows how much closer to 100% we were anyway.
SeaLevel put us on the track of it possibly being a tank odor versus an ammonia leak and it appears that's what it was.
Just wanted to post this and hopefully close the book on this particular Airstream Anomaly. More to come, I'm sure and the experience and guidance on this forum is amazing. No need to re-invent the wheel unless I insist on trying!
Air Admittance Valve / Odor / Closet / help clicker187 Plumbing - Systems & Fixtures 9 03-07-2016 12:34 PM
Urgent: strong ammonia odor in freezer jornvango General Repair Forum 25 04-22-2013 12:29 PM
Domestic RM 2310 smells of Ammonia.. Keyair Refrigerators 13 06-02-2010 01:49 PM
Sulfur Odor in 25' Wardrobe Closet ???? 2dabeach Waste Systems, Tanks & Totes 2 03-25-2009 09:24 AM
ammonia smell????? Randy Lee Refrigerators 5 08-17-2007 10:36 PM
