Old 10-29-2013, 05:24 PM   #1
ibskot's Avatar
1978 Argosy 30
locust , North Carolina
Am I wrong? Some questions...
I have been reading a ton since I got my 30 ft 1978 Argosy. I want to clarify a couple things.
About riveting, am I wrong, but if I want to hang something on the wall i just drill a 5/32 hole and pop rivet (inside not exterior) it to the wall? When do you ever have to hit a "stud"? What about anchoring a floor cabinet to the wall?
When I remodel the thing and want to move or redo the floor plan I just drill out the existing rivets and move the wall or whatever. Right?
Why does the toilet on the rear baths sit on a plywood box?
I appreciate any advice.
ibskot is offline   Reply With Quote
Old 10-29-2013, 05:32 PM   #2
LFC
Memphis , Tennessee
I use Velcro to hang pictures.
LFC is offline   Reply With Quote
Old 10-29-2013, 05:44 PM   #3
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
First if you gotta ask then yes you are! I have lived in a house of females so I am wrong most of the time! The rest rivets work for me and some of my cabinets were screwed into the wall only!
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 10-29-2013, 05:51 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The toilet sits on top of the Black Water tank. Which is under the skimpy plywood box.
Most RV toilets drop the contents directly into the BW tank. This prevents any blockage between the toilet and tank.
The tank capacity in the Argosy is probably about 12 gallons.
Old 10-29-2013, 06:56 PM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Of course a 'stud" is a stronger anchor. But if you are hanging light stuff no problem.
Most, if not all, of the cabinetry and bulkheads are pop riveted to the inner skin.
Lumatic is online now   Reply With Quote
Old 10-29-2013, 07:57 PM   #6
ibskot's Avatar
1978 Argosy 30
Even the overhead cabinets? I'd like to move that wall at the end of the double twin beds to allow for a longer bed so I can sleep without hitting my head or toes.
Old 10-30-2013, 05:41 AM   #7
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
What you're calling a stud is actually a rib. It's not essential to rivet to the ribs, but always better if you can do so. The shape of the rib makes it a lot more rigid than the (inner) skin. If you rivet to the skin alone, you can experience oil-canning— while the trailer is in motion the skin flexes under the load, which can lead to a dent or bulge or wrinkle in the skin where you installed the rivets. The heavier the load you're hanging from the rivet(s) and the fewer rivets you use to hang the load, the more pronounced the problem will be, all other things being equal.
Overhead cabinets should always be secured to the ribs. Even an empty cabinet is heavy, and a full cabinet even moreso.
Floor cabinets and bulkheads are a different critter; it's the floor, not the wall, that's load-bearing, and the rivets in the inner skin are just for positioning, not for load-bearing.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-30-2013, 11:09 PM   #8
ibskot's Avatar
1978 Argosy 30
Are the bulkheads what is over the twin beds? Or over the couch at the front near the tongue?
Old 10-31-2013, 05:57 AM   #9
Bulkheads are walls that run side-to-side in the trailer.
WBCCI #1105
TAC LA-4
Old 11-01-2013, 09:06 PM   #10
Ottawa , ON
I see those referred to as "lockers" despite the fact that I have not seen one that locks.
Old 11-01-2013, 09:32 PM   #11
ibskot's Avatar
1978 Argosy 30
Thanks folks
