Old 09-21-2005, 08:06 AM   #1
rfield54's Avatar
2002 19' Bambi
1989 29' Excella
1980 28' International
Avon , Colorado
Images: 106
Send a message via AIM to rfield54
Aluminum wool supplier?
Does anyone know of an aluminum wool supplier? No luck at my local HD. Online, all I could find is priced at $60 minimum. I suppose stainless steel or brass would do (size 00, to inhibit mouse intrusion). Thanks in advance. - Roy
AIR #2753
www.roybloomfield.com
rfield54 is offline   Reply With Quote
Old 09-21-2005, 08:59 AM   #2
Roy, I can't help on the aluminium wool, but I have successfully used stainless steel pot scourers for several years with no problems or corrosion. "Stainless" steel quickly forms a very thin layer of oxide, which causes it to be electrolytically passive, which is why "stainless" steel should not be cleaned with an abrasive. I would not use brass because of electrolytic corrosion between the brass and aluminium or steel. The above suggested link to http://www.airforums.com/forum...ead.php?t=2518
"stainless steel wool and mice" is informative.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 09-21-2005, 09:14 AM   #3
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
I used strips of aluminum window screening.
Maurice
Old 09-21-2005, 09:37 AM   #4
rfield54's Avatar
2002 19' Bambi
1989 29' Excella
Avon , Colorado
Images: 106
Nick.
Thanks Nick. I checked there first. McMaster-Carr only has stainless steel wool, minimum $83.
AIR #2753
Aluminum Trim Source? melprice Cabinets, Counter Tops & Furnishings 6 09-08-2009 06:19 PM
Stainless steel wool and mice barbwire All Argosy Trailers 14 12-02-2002 10:01 PM
Sheet Aluminum repair lee_jachter Ribs, Skins & Rivets 8 11-23-2002 08:48 AM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
